Old 02-22-2004, 08:32 PM
Vladamor's Avatar
Vladamor Vladamor is offline
Send a message via MSN to Vladamor
Troubles with interior paint
Hi there. I want to ask, why when I paint interiors, the painting from down raises with the second hand... I use Tamiya's Acrilic Paint before, but I don't like the results. So, I'm using now the Tamiya's Enamel colours... But the problem is there yet... For example, I'm painting the seats of my current S14 Autech Version with a comb. of Flat Red for the inner part, and Semi Gloss Black for the outter. The result of the red part is rough, with a strange shinning finish.
And, if I'm painting with gloss colour, what I have to do so that the result is smooth, without the brush marks?? ........
Old 02-22-2004, 08:35 PM
StephenDeli's Avatar
StephenDeli StephenDeli is offline
Send a message via AIM to StephenDeli
Re: Troubles with interior paint
Spray large areas instead of brush painting them
Current Projects- Ferrari F189 ON HOLD
Ferrari 360 Spider
Future Projects-04' Corvette Z06, Enzo, F1-2000
Old 02-23-2004, 02:23 AM
primera man's Avatar
"P-Man"
Use enamals as they take longer to dry therefore giving you more time to work with the paint.
Heat the bottle of paint in warm water first as this helps thin the paint down and makes it flow better.
If you are doing a fairly large area....put quite abit onto the brush and work quickly before it dries.
Use the correct brush size for the area. If you are doing a large area, use a bigger brush !!
Keep all the brush marks going one way and for the final finish... you should just use the weight of the brush to help smooth out the paint.
Try not to keep going over the same area as it becomes "tacky"..... as you will start to pull the paint off giving a rough finish.
Allow plenty of drying time(4-5 hours at a warm room temp) to put a second coat on if need.
View All My Models Here.
Im having trouble with my HOK paint Rye 21 Car Modeling 19 01-26-2011 01:44 PM
Interior paint summary/tips... Painting plastic, trim, bezels, vents, dash etc number50 Appearance: How To... - FAQs 5 10-31-2009 12:36 PM
A little Help with interior Paint supratuner89 Diecast Car Modeling 7 06-21-2005 02:31 PM
Help With Interior Paint... III G Man III Cavalier 3 01-24-2005 10:53 PM
This is for the guys with the painted interiors. I've got some questions to ask. PINMASTER8 Car Audio 5 09-21-2003 08:07 PM
