Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 02-21-2004, 07:19 PM
donvalleysunfire donvalleysunfire is offline
Installing new car deck
I've been told that I cannot install a new car deck in my 2000 Sunfire without moving the factory deck to the trunk and re-wiring it, because the airbags, alarm system, dome light etc are all connected to it. I wanted to buy a nice Sony deck ($200) but was told that a 2000 Sunfire needs a relocation kit and with all the installation charges, it would eventually come to about $600.
Am I being jerked around, or is this really true?
Old 02-21-2004, 10:12 PM
hopeless4life hopeless4life is offline
Send a message via MSN to hopeless4life
Re: Installing new car deck
Your being jerked around go to a real car audio place, and DON"T BUY SONY, buy pioneer or clarion. The deck has its own seperate alarm system which has nothing to do with the car. If they give ya nemore touble tell them where to go
Old 02-21-2004, 11:38 PM
Thanks. I thought so... It really didn't seem right to me that all that work needed to be done.
Thanks again.
Old 02-22-2004, 01:31 PM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Thanks again.
Not sure about the Sony unit you are looking at but I know all the Sony's I've messed with are WEAK! I'd look at just about anything else especially the Pioneer or mid level JVC stuff as a good starting put. Yes, the Sunfire has some crap in the radio but there are way around that like this... http://metraonline.com/product.aspx?sku=70-2003T
http://metraonline.com/locator.aspx?...del=670&type=1
Old 03-04-2004, 06:40 PM
muzikmannn muzikmannn is offline
Re: Re: Installing new car deck
You're correct about sony for auto gear; there crap. Besides the 2 you've mentioned i like alpine as well. However if the car has a factory alarm system it does certainly go through the factory deck and so do the chime module. If you remove the deck you will have no more factory alarm system and no more door chime when you open the door with the keys in the ignition. Also there is no ignition wire going to the factory deck so i ran a direct wire to the fuse box. There is a kit that cost $100 cdn that will allow you to run the factory harness to the trunk and mount the factory deck to the decklid so everything still works. I didn't in my car and i have no security nor chimes anymore.
Help Please, wiring issue, just installed new audio deck, having other wiring problem daniel_e_10 Car Audio 3 03-23-2008 02:26 AM
installing new cd deck BigBoyDeno Lebaron 1 07-24-2006 12:33 PM
Front Panel Lights went out after installing new stereo deck dmandave Legacy / Liberty / Baja 5 12-06-2003 07:03 AM
