Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 02-21-2004, 06:24 PM
sunnibear sunnibear is offline
Question 94 ranger leaking
Alright we got this truck only a year ago.. it is a 94 ranger it is the vehicle used only for work (5 miles one way). It just all of a sudden started leaking coolant fluid, not just leaking running out. It starts to run about 2 min after truck is started, vehicle at this time is not over heating. If you turn on the heaters it blows steam in through the vents. It is happening on the passenger side in back of the tire. I have checked the overflow container there are no leaks (coolant is coming from area under it.) I have checked water pump, water pump hoses, radiator hoses, and overflow hose. There is no coolant in the oil. Other then that it runs fine. Any suggestions on what to check what it could be? thank you
Old 02-21-2004, 07:06 PM
Bronco2 Bronco2 is offline
Re: 94 ranger leaking
Heater core. The coolant you see hitting the ground is probably coming out of the A/C drain.
Old 02-21-2004, 07:57 PM
ranger leaking
The water that is coming out is green. the overflow resevoir does get dry, the radiator hasn't. The A/C hasn't been running (A/C is the only thing that hasn't or doesn't work since we got it a year ago).
Old 03-02-2004, 04:29 AM
bladerunner52 bladerunner52 is offline
Definitely heater core - my B3000 did the exact same thing. Don't know about the earlier series but I had to remove the entire dashboard to get to it.
Ranger 1998 roof leak markdpro Ranger | Courier 1 04-24-2010 03:18 PM
1993 ranger has issues dimwittcaddy Ranger | Courier 3 04-23-2009 09:46 PM
1994 Ranger 4cyl check engine light/ABS light wont start on cold mornings 94rangerproblems Ranger | Courier 1 03-21-2009 06:40 AM
1996 Ranger 2.3L Code P1443 sea-doin-it Ranger | Courier 3 03-07-2009 10:56 PM
ranger leaking sunnibear Ranger | Courier 0 02-21-2004 07:56 PM
