Old 02-21-2004, 04:57 PM
FrozenPea FrozenPea is offline
Question Tamiya Clear (X-22) Woes
Hi guys,
I've been a long time aircraft modeller, who recently branched out and did a tank, and now trying my hand at doing a Toyota Soarer (Fujimi).
I've learnt alot from reading this forum and would like to thank many of you for contributing such good tutorials, tips etc etc. Anyway, onto my problem, which i hope you guys can help me with.
I have airbrushed the body of my car using Tamiya XF-11 J.N. Green with great results, and obviously i want to apply a gloss clear over the top to apply decals and polishing/waxing etc. The problem is that when i airbrush the clear (X-22), it seems to spread a fine misty white powder-like coat across the rest of the model (area that is not directly being sprayed). It is extremely noticeable in the panel lines, door frames and grills. I've seen no other mention of this problem, however like most things in this hobby, there's probably a very simple solution to overcoming this.
If there's no simple fix, i'd be open to suggestion to use other brands of clear gloss - but i've always been very impressed by Tamiya paints and tend to use them almost exclusively these days.
Thanks for your help.
Old 02-21-2004, 05:07 PM
mike united's Avatar
mike united mike united is offline
Your applying it too thickly. Do many light misty coats, about 4-5 and then one final coat slightly heavier coat, this to stop any orange peel.
This is my method and im happy with it.
Good luck........
Later, Mike.
Old 02-21-2004, 05:32 PM
Re: Tamiya Clear (X-22) Woes
Thanks Mike, I will try some lighter coats. I can't say i'm getting the orange peel effect with my current application, but perhaps the lighter coats will fix my problem too.
Old 02-21-2004, 06:54 PM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
The whit dust when spraying x-22 is caused by some of the atomized paint drying before it hits the surface being painted. What are you thinning with? Adding more thinner to the clear, or changing the formulation will more than likely solve your problem (it does for me). Happily, the white dust can usually be wiped/polished away.
X-22 is my favorite for clear overcoat. I've tried a number of others, but tend to have best luck with the Tamiya stuff. Among other things, it doesn't seem to craze or crack after drying- a problem I've certainly had with other clears. And with a bit of patience, it can be polished to a terrific shine.
Good luck!
Old 02-21-2004, 07:50 PM
Using the Tamiya thinner. i had a feeling the thinner has something to do with it - will defenitely try adding more! I might also wait until this heatwave has passed (41c degrees here and rising)
Thanks.
Old 02-21-2004, 08:04 PM
MPWR's Avatar
See also my post on "what is acrylic thinner" (too lazy to retype it all!)
http://www.automotiveforums.com/vbul...d.php?t=191979
Oooo, 41c.... Sounds nice!
Old 02-23-2004, 01:59 AM
primera man's Avatar
"P-Man"
If you have a perfect paint job...dont put a clear over it !!
View All My Models Here.
tamiya lotus europa special teszion Completed Projects / Gallery 12 02-05-2012 12:41 AM
