Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon
Old 02-20-2004, 12:00 PM
dagmbs dagmbs is offline
Where is the fan sensor?
I have a 97 neon lx that is overheating. The fans are not kicking in but the mechanic cannot find the sensor. Any help would be appreciated.
Old 05-15-2004, 09:33 PM
jtk2069 jtk2069 is offline
Lightbulb Re: Where is the fan sensor?
Look under the battery box on drivers side. I am having the same problem. I called the dealer and they explained the part to me. It is 1 1/2 X 1 1/2 with a plug on the bottom it is mounted with 2 screws on the uni-body. I am almost sure this is fan relay as the dealer has explained to me. They told me the relay is anywhere from 50-75 $$. Please let me know if this works for you. I was also wondering if your Neon is A DOHC. I am starting to think this is the only model that has the fan relay located on the uni-body. You can also hardwire it to a fuse in fuse block, so it will run when the ign. is on.
Old 05-16-2004, 07:16 AM
Re: Re: Where is the fan sensor?
Thanks for your reply. I'm not sure what you mean by a DOHC. I found out that the head gasket had gone in the end and i have now changed the car. Hope you get your problem sorted.
Old 02-05-2005, 08:58 PM
gschulz gschulz is offline
I just want to say thank you. I am a good troubleshooter and I knew I had a bad relay but had no idea where it was. That was it, I bypassed it and the fan came on. I have a SOHC so its not exclusive to the DOHC models, but some neons have the relay with the fuses. That would have been to easy though. Thanks again.
Class Project - The Tailgate Sensor - survey and feedback jmsapp COMPLETELY off-topic 9 11-24-2009 08:30 PM
Please help,tell me where the cps sensor is in my engine I have pics inside!! b16Civic Century 11 08-21-2007 05:56 AM
wheres the oxygen sensor? aleman3d Stratus 0 05-16-2005 03:24 PM
where the o2 sensor located? crx hf '88 - '91 Civic | CRX | Wagon | Shuttlee 11 08-02-2003 10:11 PM
