Go Back   Automotive Forums Car Chat > Buick > Century
Old 07-21-2007, 04:13 PM
b16Civic b16Civic is offline
Where is the cps located on my 89 buick century 4cyl.? Help
Hello i got frustrated trying to find the damn cps on my car, ive crawled up underneath,looked everywhere and unless they gave me the wrong part im not going to find it.Ive looked at the DIS module and still nothing.I cannot find it, Im either blind or its really hidden,Could it be that it covered with a cap or somethin? this is the cps they gave me
Please help.Its a 4 cylinder automatic.
Old 07-21-2007, 10:27 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: Where is the cps located on my 89 buick century 4cyl.? Help
Under hood, center, upper engine area, rear side of engine, front of coil pack, mounted in engine block
Old 07-21-2007, 11:09 PM
is it covered under something? cuz im stumped.
Old 07-23-2007, 10:16 PM
Please help,tell me where the cps sensor is in my engine I have pics inside!!
I cant seem to find the cps sensor,where does is it?Is it covered with something please help,Here are some pictures to help you tell me.Its a 4 cyl automatic 1989 century.
Old 07-24-2007, 07:39 AM
bruceallmighty bruceallmighty is offline
Re: Please help,tell me where the cps sensor is in my engine I have pics inside!!
u can also try autozone .com repair info,component location,pretty good step by step insrutions if u have no manual.
Old 08-05-2007, 06:02 PM
I tried ,but no luck pardon my ignorance,but ccan someone please help me find the dam sensor?
Old 08-06-2007, 06:55 PM
HotZ28's Avatar
AF Moderator Elite
Wink Re: Please help,tell me where the cps sensor is in my engine I have pics inside!!
Your two threads on the same subject were merged into one!
BE COURTEOUS: AVOID DUPLICATE POSTS
Do not post the same discussion more than once on a discussion forum or on many forums. Duplicate discussions can be frustrating for other members, especially for those whose time and energy is limited. Weeding through the same discussion in multiple locations can be not only frustrating, but down right annoying. Duplicate discussions will be deleted. Reposting the same message repeatedly can be interpreted as SPAM and could result in the loss of your membership. Also be conscious of your fellow members and avoid making meaningless posts for the sole purpose of increasing your post count.
Old 08-06-2007, 08:37 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Look on the side of the block. Should be held in by a single bolt. It can be either in the middle or close to the bell housing. I would anticipate it will be on the firewall side of the engine but not absolutely certain.
Old 08-07-2007, 02:11 PM
Does it have a plug connected to something else? If one single bolt holds it in why does the sensor have 2 holes? If it has a plug should a go around disconnecting the plug to see which fits? Does it definately go in the block or on the tranny? upper or lower engine?
Old 08-10-2007, 02:59 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
IF it's a 4-cylinder, it's connected to the bottom of the ignition module bracket. you'll have to remove the ICM and coils to replace it. Follow the spark plug wires around the back of the engine to the coil pack and that's where it is.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 08-21-2007, 12:02 AM
thanks alot,is it under the bracket covered and will it have a plug so i can more easily identify it? aslo does it just come off and in goes the new one or does it have to be setup someway?
Old 08-21-2007, 05:56 AM
richtazz's Avatar
you cannot see it when installed in the engine. Once you pull the ICM/coils, you'll see it bolted to the bottom sticking out. Diconnect the old one, reconnect the new one, and reinstall the assembly on the engine.
