Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 02-20-2004, 09:25 AM
SkiNutJones SkiNutJones is offline
Send a message via AIM to SkiNutJones
Fog Light Help!
My passenger side fog light went out. I was trying to take it off last night and stipped the hell out of what I can see is the only thing holding it on. Now I dont know what to do. Any suggestions?
Old 02-20-2004, 09:51 AM
xjoeharperx xjoeharperx is offline
Send a message via Yahoo to xjoeharperx
Re: Fog Light Help!
What part did you strip?
Old 02-20-2004, 05:26 PM
Rulez Rulez is offline
Send a message via AIM to Rulez
Re: Fog Light Help!
There is only one 10mm bolt that holds the foglight on. Take that out and pull the light towards the center of the car.
Mike Rule
2000 Mitsubishi Eclipse GT Turbo
www.club3gfl.com
www.fiautosports.com
Old 02-23-2004, 11:04 AM
Mine has a Philips screw where I'm guessing the 10mm bolt should be as soon as I turned the screwdriver it stipped the screw. I didnt see the bolt anywhere I'll keep looking though. If your looking at the fog light to the right of it set behind it is the location of screw.
Old 02-25-2004, 08:58 AM
Re: Fog Light Help!
What year is your car?
Mike Rule
www.club3gfl.com
Old 02-25-2004, 01:20 PM
bigmikey bigmikey is offline
Send a message via AIM to bigmikey
on mine the nut that the srew goes into came loose from where the nut is held on. I was able to reach a 10mm wrench around onto the nut and hold it steady, then i could unsrew the srew. once u loosen it up enough to where you can use your hand do it by hand so as not to loose the nut
Old 02-25-2004, 10:57 PM
Re: Fog Light Help!
Its an '01, I'm guessing that when I wrecked it they just put the screws in instead of the bolt. I just drilled it out and replaced it with a 10mm bolt. I changed both of them for unifomity sake. Thanks Guys. The driver side came right out with no problem. Thats just my luck.
Fog lights not working misguru Cherokee 1 12-31-2009 12:55 PM
2000 Denali Fog Lights...Help.Need Replaced Lightgomez Yukon 4 04-18-2006 11:03 AM
97 Grand Caravan LE Fog Lights Help BronxJigster Caravan | Voyager 4 02-27-2006 01:27 AM
RS Fog light help / and pic identification ^^ toneee69 Off-Topic 15 09-10-2005 01:54 AM
Fog Lights HELP!!!!!! 94TramsAmGT Camaro Discussions 2 05-03-2004 11:23 PM
