Old 02-20-2004, 04:20 AM
V-K V-K is offline
Send a message via AIM to V-K
Towing Capacity?
What kind of weight should I be able to tow with my 4 door Civic? I have an 1900 lb. trailer I need to pull about 300 miles. Think the car can hanle it?
Old 02-20-2004, 05:47 AM
redmanjd redmanjd is offline
this is not a hauling vehicle. It only has a unibody, not a frame to bolt a hitch to . I have seen people tow jet skies with them but not something that alost wights as much as the car itsself.
95 b18b
new crank, eagle rods, je 10.5 : 1 pistons, 8lb flywheel, stage 3 act clutch, billet aluminium and urathane mounts, balanced rotating mass, 14.3 @ 93mph
New additions, teo4h turbo, ssautochrome turbo manifold, custom piping, turboxs bov, dsm 450cc injectors, greddy e-manage fuel controller 13.07 @ 107 untuned
Old 02-20-2004, 08:49 AM
viper_2_4's Avatar
viper_2_4 viper_2_4 is offline
Send a message via MSN to viper_2_4
I think in the manual it should say what it is rated at to tow, but I can't imagine it is that high......
Old 02-20-2004, 09:06 AM
sastanley's Avatar
sastanley sastanley is offline
AF Premium User
Send a message via AIM to sastanley Send a message via Yahoo to sastanley
Re: Towing Capacity?
I have a hitch built for this car installed on my car rated at 2,000 lbs. - techincally I think that puts the car at Class I capable. 1,900 is pushing it, but inside the limit if that is the total weight you'll be hauling.
I often pull a boat/trailer combo that weighs about 1,100 lbs total. The DX's 92 HP motor wasn't real happy with me, but seem to handle it fine. I still got 27MPG on a 400 mile trip, with 3 people in the car.
I have hauled more...a heavy duty utility trailer loaded with lumber, but only a few miles. The car didn't have a whole lot of giddy-up, but made it the short distance without any problems.
A 5-speed is much better suited for this type of application. I'd worry, and not pull anything bigger than a jet-ski, if I had an automatic. (I also own a 14ft. single-handed sailboat which weights about 400 lbs. total, which was the original reason I put on the hitch...I suspect that is about equivelant to a jet ski in weight.) When I haul a utility trailer, I tend to run in 4th gear also, since I think 5th is too tall for towing, and makes the engine work too hard at low RPM.
The real key is balancing the load so the trailer axle holds as much weight as possible. Keep the tongue weight light to keep the vehicle itself balanced. Without a scale, I'd guess I try to tow things with about 30-50 lbs. of tongue weight. Just enough to keep the trailer from pulling up off the ball.
Also, make sure your brakes are in good condition too, since they are used to only stopping about 2,400 lbs (car + driver). I have Brembo "OEM" rotors and AEM pads on my car.
But like readmanjd said, they aren't really designed as a towing vehicle..I probably wouldn't haul anything bigger than my 1,000 lbs. boat any type of distance, so use your own judgement...what type of terrain do u expect to see on your trip? Flat roads near the coast are one thing, but hills and mountains are an entirely different beast.
-Shawn
'91 Civic DX sedan
DOHC ZC, I,H,E, urethane bushings and mount inserts, rock chipped hood, some rust, stock steelies, nice comfy Integra seats, and the A/C works! What else could you want from an 18 year old car with 241,000 miles? Working on getting the Si tranny in now
Old 02-20-2004, 09:13 AM
MethodMan420's Avatar
MethodMan420 MethodMan420 is offline
WOW I thought I saw someone ask if you can tow with a civic .. just thought I better come look for myself ....geesh some people.... but then again my grandfather has towed a log wagon full of wood (about 3000# tongue weight with his old 88 Toyota, from the day he got it. Never underestimate the power of Rice I guess.
Ok I guess it could be done but I dont wanna be following you on the onramp to I-75 hehe
Old 02-20-2004, 10:57 AM
Killa_CRX's Avatar
Killa_CRX Killa_CRX is offline
When Civics Attack!
I've towed my mom's '90 Chevy 1500 extended cab truck without much trouble when her transmission went out.
That's a little over 4,000lbs for the truck, and then my mom, stepdad, little brother, and two little sisters and myself.... and my 91 DX pulled it all like champ over 70 miles back to my house!
Only thing was, the truck was hooked up via tow rope, and my stepdad was working the brakes in my mom's truck, so I didn't have to deal with stopping it too... I would say deffinately make sure your brakes are in GOOD condition though.
Honda Enthusiast
Old 02-20-2004, 11:14 AM
sastanley's Avatar
AF Premium User
Nice - Go Civic!
Old 02-20-2004, 12:54 PM
V-K V-K is offline
I see mixed opinions, but maybe I'll try to borrow, or even rent, a truck for this. Thanks guys.
Old 02-21-2004, 12:30 AM
travagliante's Avatar
travagliante travagliante is offline
Id definatley go UHAUL $19.95 + miles
lol
Good luck
Old 02-21-2004, 03:38 AM
90civicracer's Avatar
90civicracer 90civicracer is offline
Send a message via AIM to 90civicracer
Yeah of if you have a buddy w/ a truck/suv that'd be even easier, just tell him you'll buy him a case of beer or pay for gas or somethin, lol.
***90 Civic EX 4 Door***
Ace$nyper: yea it did woo woo 4500 posts i should be ashamed *kills self*
90civicracer: haha you killed yourself you got
Ace$nyper: OMFG LOL that might be the funniest thing you EVER posted
bwhahahaha
Old 02-21-2004, 11:23 AM
Re: Re: Towing Capacity?
Yep thats so true. I offer my friends linch, pay for gas, and fill it up when im done.
Works all the time. lol
Old 02-21-2004, 03:09 PM
Hell its worked for me when my friend wanted to borrow my car. Last year for his prom he didnt wanna drive his shitty lil '92 mazda 2200 so he gave bought me lunch and filled up my tank when i let him use it.
bwhahahaha
Old 02-21-2004, 04:53 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
my 90 STD pulled stuff all the time. i put a u-haul tow hitch on it.
things ive pulled:
a 16 foot aluminum flatboat and trailer. probably weighed 1500 lbs with all the gear in it, and brought 3 people with me. handled it like a champ, just had a little trouble pulling the boat back out of the water on a backdown boat launch ramp. not enough traction with the concrete being wet, and i had to get the three friends to push the back of the car while i floored it, but the car finally caught dry cement and pulled it out easily.
i also towed a CRX Si with b16a in it from baton rouge to new orleans which is about 90 miles. i used a uhaul style tow dolly, and i imagine that the combined weight of towdolly and car was 2500+ a little more.
all of this was with the stock d15 with 4 speed tranny and stock 175,000 mile clutch.
now that my 88 has the b16a in it from that CRX, im anxious to throw the tow gear on it and build a mini trailer out of the back end of one of my junk hatches
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 02-23-2004, 07:14 AM
nemo_wolf's Avatar
nemo_wolf nemo_wolf is offline
Send a message via AIM to nemo_wolf Send a message via MSN to nemo_wolf Send a message via Yahoo to nemo_wolf
ohhh ohhh if you do do that PLEASE take pics!
AF Bay Area Crew
91 civic LX sedan : Dec. 3rd 01 - Dec. 9th 02
88 civic DX hatch : Jan 14th 03 - Oct 05
96 Zamboni Model 552 : done working there
00 Civic EX coupe : Oct 05 - Sept 2010
11 Scion xB : Sept 2010 - Present
Old 04-17-2010, 04:15 AM
account account is offline
towed 1751lbs on axle for over 17k miles while traveling around the country. No problems but a blowout on a used 20 dollar tire while on freeway. clutch working great. Also hauled that load + 4 girls up grueling roads up oregon mountain.
setup: modified class 3 jeep tow hitch + steel from recycle center + steel to sandwich all parts of the frame where tow bar bolts into.
Make your sh1t happen
Last edited by account; 04-17-2010 at 04:17 AM. Reason: misread someone's text above
2005 Sienna Tow Hitch & Tow Capacity gnrboyd Sienna 2 02-24-2014 10:01 PM
Towing capacity of a 91 Civic wagon?? civic minded '88 - '91 Civic | CRX | Wagon | Shuttlee 10 08-14-2003 07:46 AM
1983 C20 Suburban towing capacity? SolTheHoelessPimp Suburban 0 04-01-2003 09:39 PM
towing capacity crips10 Silverado 2 12-13-2002 04:45 AM
Towing capacity..... kicker1_solo '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 11 01-21-2002 03:35 AM
