Old 08-13-2003, 03:09 PM
civic minded civic minded is offline
Question Towing capacity of a 91 Civic wagon??
Hello,
My first post here, and I desparately need some information. We just had a baby, and bought an old shitbox (but in great shape) 91 wagon for the extra couple of doors; our 2000 hatchback just doesn't cut it for car seats.
My question is this: I work construction and will be on the road this summer, and so my family can come with me we're looking at purchasing a little trailer. The car already has the right ball for the hitch, and the trailer weighs 2000lb (gross).
I think that the car will be able to pull the trailer safely, but I'm not sure. Anybody know for sure?? No positive hits on a google search, so I'm hoping you folks can help me out.
Thanks in advance!
Old 08-13-2003, 03:13 PM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
2000lbs? damn ... does gross mean like total weight?
What you will want to do is find out the GAWR (or some shit like that) rating for your car, i got no idea where to find this, but i will look around a bit.
Sastanley tows a boat with his 91 dx sedan, with his entire family in the car and says it does fine ... i dunno what the boat weighs though.
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 08-13-2003, 03:40 PM
Smile
Ok,
The GVWR is 1510kg (~3300lb), and the GAWR is 790(f) and 745(r).
So can I assume that I can tow 790+745=1535kg or roughly 3400lb???
What's the difference between GVWR and GAWR? From the acronym I'd assume it's Gross Vehicle Weight Restriction and Gross Axle Weight Restriction?
P.S. Gross=total
Old 08-13-2003, 03:54 PM
sastanley's Avatar
sastanley sastanley is offline
AF Premium User
Send a message via AIM to sastanley Send a message via Yahoo to sastanley
UH....the hitch I installed and use has a 2000 lbs. capacity...the largest boat and trailer I have towed is about 1200lbs all up (boat at 700, trailer at ~300, gear ~200)...you can DEFINITELY tell it is there behind you, and it doesn't go anywhere fast...although I did still get 27 MPG (while my buddy in his Suburban with same type of boat got his usual 15 lol), but I had to turn off the A/C on hills, or accelerating into traffic, whereas he didn't even know his boat was there
Small sail boats (especially a 19' Lightning since they sit low in their trailers and stay in the cars slipstream) are easy to tow...once you are up to speed the thing handles great. The key is to keep the tongue weight light so your rear-end doesn't sag and reduce traction up front.
I've also towed a utility trailer (when my buddy lost the ball off his Blazer on the side of the road - the mighty Civic to the rescue!!! )with a load of lumber (est. weight 1000lbs.) and it was fine, however, the sheer windage of the big-ass trailer and the stand-up ramp they have made things pretty slow with only 92HP....Anything above 45MPH or so required no 5th gear usage, and significant lead-foot action (moreso than usual highway cruising) to overcome the windage
However, I dunno if the stock brakes and the suspension/frame will handle much over 2000 lbs. safely...I don't think unibody frames are ever gonna be strong enough for anything other than a Class I hitch. (if I have my facts straight, that is a 2000 lbs. with 200 lbs. tongue rating)
Welcome to the board tho...
-Shawn
'91 Civic DX sedan
DOHC ZC, I,H,E, urethane bushings and mount inserts, rock chipped hood, some rust, stock steelies, nice comfy Integra seats, and the A/C works! What else could you want from an 18 year old car with 241,000 miles? Working on getting the Si tranny in now
Old 08-13-2003, 04:14 PM
ZC is new terminology for me (sorry, I'm not much of a car guy ). Sounds like some sort of stabilizer in the suspension, but I dunno.
When you say don't weigh down the tongue, I'm assuming that means keep the trailer weight distributed towards the rear of the trailer, ko-rekt?
Thanks for the welcome, and the info. Keep it coming!
Old 08-13-2003, 04:23 PM
sastanley's Avatar
AF Premium User
Yes...exactly...I usually keep the tongue weight on the trailer light enough I can pick it up and lay it on the ball with minimal effort (one-armed and not really stressing), so the back-end of the car doesn't sag, and #1-look funny, #2-reduce traction to front drive wheels, & #3 scrape shit in the back of the car namely my exhaust
The ZC is a DOHC 130 HP motor that bolts into our cars and our transmissions imported from Japan that came in 4th gen Civic's and CRXs, but wasn't available in the States. It was called the "Si" trim in Japan, while we got the SOHC d16a6 motor with only 108hp as our "Si". Since you are new to the 88-91 Civics, you probably have no clue what all this means, and that's OK. When you have some time, go check out a site like this - http://hybrid2.honda-perf.org/tech/4gtech.html
- that helps to explain what us crazy enthusiasts do for more power in our little Civics
The stock motor in the DX/LX in the US is a d15b2 with 92 HP, my current motor with 214,996 miles on it, so I am gonna like my 40HP upgrade
-Shawn
'91 Civic DX sedan
Old 08-13-2003, 07:35 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
from what i hear and have seen, 750lbs is the max to be towing with a 91 civic.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 08-13-2003, 10:26 PM
Thanks for the info, y'all.
Sounds like we'd be pushing (or blowing the doors off ) the boundaries of safety if we chose to tow that trailer with whitie.
Too bad, but good to know.
Now, on to Plan B...
Old 08-13-2003, 11:18 PM
jeef jeef is offline
Send a message via AIM to jeef Send a message via Yahoo to jeef
haha nice, feel free to stick around the 4th gen board though... we generally are a nice bunch of ppls
90- crx si w/ a D16a Vtec and a few goodies, oh and 60k miles on it heh
Old 08-14-2003, 12:10 AM
XxLuckyLisaxX's Avatar
XxLuckyLisaxX XxLuckyLisaxX is offline
Send a message via AIM to XxLuckyLisaxX
sorry didnt really read all your guys writing and shit too much for me, i just wanted to comment that i towed my 90 hatch dx at its full curb weight with my 91 hatch si, i was quite impressed with its performance, woop woop!
Keep it real, and share the knowledge.....
Say NO to Primer!!
Old 08-14-2003, 08:46 AM
sastanley's Avatar
AF Premium User
NICE - that's freakin' awesome!!! Did u do that with a car dolly (front wheels of towed vehicle off the ground??) or a full double-axle trailer with the whole car on it?
-Shawn
'91 Civic DX sedan
2005 Sienna Tow Hitch & Tow Capacity gnrboyd Sienna 2 02-24-2014 11:01 PM
Towing Capacity '93 525IT WAGON ????? TheBman69 5 Series 0 02-24-2006 08:21 AM
1983 C20 Suburban towing capacity? SolTheHoelessPimp Suburban 0 04-01-2003 10:39 PM
towing capacity crips10 Silverado 2 12-13-2002 05:45 AM
Towing capacity..... kicker1_solo '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 11 01-21-2002 04:35 AM
