Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 02-19-2004, 11:55 PM
CrazyModGSR's Avatar
CrazyModGSR CrazyModGSR is offline
Send a message via AIM to CrazyModGSR
anyone with forced induction in CT, please HELP!!!
Hi. Looking to buy a turbo'd teg, but I am not sure how this will affect CT emissions. When I register the vegicle, they would probably give me a date for emissions. I know the car does not have a cat, so I would have to have one installed for emissions. Also, I've never owned a turbo car before and will be learning how to tune, etc. as I go. It's a GS-R running around 10 psi on stock internals with a lowered compression head gasket. Guy also said he's got it running slightly rich, rather than lean and chance of blowing the engine. Basically wondering what any other people in CT plan on doing, or what needs to be done to get their normally NA car that's boosted through emissions.
Thanks much
Tim
Check out my 'teg at http://www.cardomain.com/id/crazymodgsr
Old 02-20-2004, 05:39 AM
redmanjd redmanjd is offline
all you have to do is turn the fuel down, doesit have an air fuel controller? is so just turn the values down till you lean it out some . then let them test for emissions(they dont run it that hard). And after you pass crank it back up again problem solved
95 b18b
new crank, eagle rods, je 10.5 : 1 pistons, 8lb flywheel, stage 3 act clutch, billet aluminium and urathane mounts, balanced rotating mass, 14.3 @ 93mph
New additions, teo4h turbo, ssautochrome turbo manifold, custom piping, turboxs bov, dsm 450cc injectors, greddy e-manage fuel controller 13.07 @ 107 untuned
Old 02-20-2004, 07:46 AM
Re: anyone with forced induction in CT, please HELP!!!
it comes with a turbo timer, gauges, and apex super sfc. only problem is i currently know nothing about turbo tuning/mapping, etc., so i need to find a good tuner as soon as i buy the car, until i learn it myself. maybe not the best choice buying a turbo car that i don't know how to tune (esp. being a daily driver)
Old 02-20-2004, 08:50 AM
i really dont know too much about the apexi. all i hear is its not to hard to turn the fuel down. i would check a site called homemadeturbo.com they have a descusion forum and tech articles. its alot of help
95 b18b
How can forced induction increase engine efficiency? caffeineaholic Engineering/ Technical 4 07-17-2010 01:41 AM
anyone with a 4.0L: need help with wiring plug connections and wire colors randy78 Cherokee 0 08-14-2009 04:12 PM
Need help with my 1995 gsr please help FUNEZ007 N2O | Turbo | Superchargers 14 01-13-2005 06:00 PM
All of you guys with forced induction or built top ends... ExoticTegra Forced Induction 7 11-18-2003 11:25 PM
Anyone with a Helms manual, please help!!! red97gtp Park Avenue 1 09-05-2003 06:08 AM
