| N2O | Turbo | Superchargers Tech forum to assist in Honda/Acura Performance. |
Need help with my 1995 gsr please help
I own an acura 1995 gsr with supercharge but i dont know what to do next or what to instal. the car is complely stock so if you have some good idead of how to tune up this integra or what should I install first let me know thanks
Re: Need help with my 1995 gsr please help
what do you want the car to do? track car? daily driver? drag racing? how much power do you want? need some of these questions answered before we can give solutions.
Black 1999 Honda Accord LX, Bombz Cold Air Intake, DC Sports Ceramic Exhaust header, "Rally racing" Foglights, 400 watt coustic 401SE AMP, 450 watt Bazooka TVB 141 Tri-vent triangle sub. 220 watt Pioneer 6.5" 3-way (in doors). To come: Dynamat, Borla exhaust system, and 17" Koenig Absolute (black w/ chome lip), Coilovers, & camber kit (1-1.5 drop), Extensive Engine mods. check me out on: http://www.cardomain.com/memberpage/515191 |
by stock i assume you mean totally stock. well for starters try an header and exhaust. I would also install an VAFC or something along the lines of that, i dont know wheather you are running a centrifucal or roots type blower, fuel is gonna be needed as im sure you havent done anything there yet.
1996 GSR w/ 1995 OBD-1 B18C1, Hondata S200 w/ P61 ECU, LS Tranny w/ Quaife LSD,ClutchMstr Stg 5,T/4 AR .60 w/ HKS Wastegate,RC 660 cc Injectors,Had Throttlebody,Skunk2 Intake Manifold,Eagle Sleeves,JE Pistons, Carrillo Rods,Stock Head & Internals,Thermal 3" Exhaust w/ no Cat,AEM Fuel Rail-Riser-UEGO-Cam Gears-Pullies-Fuel Filter,255 Fuel Pump,MSD 6A,GReddy Front Mount, 2-12's, 3 Amps,MB QuartComponents,Type-R Lip & 00 Head & Tailights, 2000 Integra Type R: Totaled
u know i don;t have a fuckin clue what u guys are talkin about...
can i be friends with one of yall..get some tutooring maybe... i got a 96 dx..i jus put a aem cai...apexi muffler..didn;t have money at the time for the whole system..anyways for my 106 hp i think that was good... did a coupel things on the outside and thas about it... but u guys talkin the real deal... i wanna get a obdII b18c1...gsr mototr..and turbo that... ^ terms i know,.,.but what u guys were talkin about....damn... "centrifucal or roots type blower"?? i mean wtf???? HELP |
sorry bout the typos...am at work
Well i want my car to be a a daily drive but i want to have enougth power to kick some v8s
I m getting headers and catback exhaust If you know a web or aplace where i can get good prices on parts please let me know |
one more thing do you all know why my heater would not work?
all the air i get is cold even when the ac is off . the car does not over heat but i can get heat from it could it be because of the super charge I bouth the car with the super charge on it so i POlogize for not knowing |
change the thermostat and the radiator cap and that should fix, in all probabilty the thermostat is stuck open but try that and if that doesn't fix the problem you may have to look into something dealing with the heater core
Built and boosted... "I feel the need.... the need for speed!" http://www.automotiveforums.com/img.php?313283teggie2.JPG |
Go to kteller.com and buy a 2.5" high flow cat, and 2.5" stainless cat back piping and a magnaflow muffler.. If you want it to not be too loud get a resonator too. This setup shouldn't cost you more than 700 installed and you'll definately be happy with it. It's almost identical to mine except I'm running a custom 2.5" to 3" cat and 3" Piping.
1993 Honda Civic EX (B18C1 Swap Supercharged at 14.5PSI) Bored .20 over, 9.8:1 Arias Pistons, Eagle Rods RC 440 Injectors, Walbro 255LPH Fuel Pump, Fidenza Cam Gears NGK Wires, NGK Plugs, Intake, Integra Type-R Header High Flow Cat, 3" Kteller Exhaust with Magnaflow Muffler B&M Fuel Pressure Regulator, HONDATA S200 w/Boost Tuned Wanna race? AF MEET IN LOS ANGELES! |
Since you havnt mentioned what SC you have yet, lemme give you the basics.
First, if you are still on the stock piping, then, replacing that will give you many improvements. colder plugs gapped between .032 - .038 will help. A boost gauge at least will do, so, you can tell us where your boosting at (also so you will know yourself). Hey Bbotoxygen, What SC are you on? Hows the duty cycle on the 440s holding up on 14.5 psi?
99 [email protected] psi si- I voted for the Terminator for Gov. 95 HB- B16a2- SC34@12psi WTB: USDM B16a2 or B16a3 complete short block. pm is the key. FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me. |
Re: Re: Need help with my 1995 gsr please help
I'm making power all the way to redline so if I move up my redline a little I should make some more power.
Re: Re: Re: Need help with my 1995 gsr please help
With that being said, and you being at 14psi, i believe a cooling system and hondata gasket would be beneficial to your setup. If you ever get intake temps, you should post it up before and after cooling.
Re: Re: Re: Re: Need help with my 1995 gsr please help
I have a hondata gasket and no cooling. I haven't gotten my temps taken though. What do you run 9 psi with? Right now i'm using the MVM stepper pulley and a CRV crank pulley.
running 9.5 psi on motorvations motorsports stepper pulley. with the mvm stepper and crv, i pulled 12.5psi. didnt like it.
What didnt you like about it? Were you making less power or was it just the temps you didnt like? Are you running stock internals?
