unstable.
my 91 LX 2.3's steering wheel starts to wobble slightly at 45-50 MPH. and my car feels like its unstable. anyone know what the problem is?
Re: unstable.
Out of balance tires, warped rotors, bad struts. Many options.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex -1999 Ford F150 |
Re: unstable.
wheels may need rebalancing or the suspension needs some adjustment.
Re: unstable.
i just got brand new tires last week, had them balanced and 4 wheel allignment. but i was thinking it was the suspension cuz the guy i bought it from planned on gettin the 5.0 so he upgraded the suspension to "heavy duty"(whatever the fuck that means)
Re: unstable.
What size tires did you go with?
Wheel bearings another possibility.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world has lost one of the truly wonderful people...
Might want to check your ball joints. My buick was like that untill I replaced them.
Grand National. Going fast with class. Voted FASTEST street car on AF. Here is the proof!!! 1987 Buick Grand National. Back in action!!!! 1999 Ford F-250 Tow rig from hell 598 Ft-lbs. ASE Certified in... Mobile AC On Highway medium duty diesel engines. Off highwayy medium duty diesel engines. On highway trucks. Working on the eletronics certification Member ofA.A.N.B.C- Afer against non boosted crews #2 |
Re: Re: unstable.
Otherwise, visually inspect the bushings, struts, and balljoints for small cracks or signs of aging. Test these components by driving over some speed bumps at slow speeds and sharply turning the steering wheel. Listen for any abnormal or unpleasant sounds. Good suspension should respond quietly. |
Re: unstable.
My Dunlop SP 9000 sports wobble like mad on any slightly bad road.
I just got done replacing the brake pads and rotors on my moms civic and there is no more wobble at all. And it usually happend around 40 - 55ish. Check em out, could be that simple.
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears. |
Re: unstable.
Does this happen when braking or under acceleration? I would say rotors as well. Hope you dont have a bad tie rod end. Have you gone back over your lug nuts since you had the new tires put on? You may have a loose lugnut or a tire bolted on at an accidental angle, causeing it to wobble.
Re: unstable.
it happens when im just cruising along, when i accelerate it is stable, as well as when i brake.
Re: Re: unstable.
if at all possible, support the car on the lower control arms in front and try to wiggle the suspension and steering components with your hands. try to move the tires up-and-down and side-to-side. if movement is excessive at any joint, you may need to replace bushings or balljoints or even entire arms. this is also a good way to test wheel bearings. you'll be able to tell if you support the car on the control arms and try to wiggle the tires. good luck.
-Andy '89 Mustang 5.0 - How fast? i'll know this weekend. '86 Mustang LX - Shortblock is built, now for the rest of it. "Put the subject before the verb, hmm? Fail this class, you will." -Yoda teaches english class. |
Re: Re: Re: unstable.
im pretty damn sure its not the clutch considering its an automatic and im also sure its not the allignment cuz i just had a 4 wheel alignment last week. ive realized my car sucks, its slow and has no potential. what im probably going to do is get full exhaust, wheels, paint and sell it to some mexican fora few grand. by that time i'll have enough experience to get a 5.0 |
Re: Re: Re: Re: unstable.
the mexican thing aint cool, if your dash is shakin too maybe your drive shaft needs to be balanced or replaced. it happened to me once but my wheel wasnt shakin, but the dash was shakin alot. good excuss to buy that aluminum drive shaft. |
