Engine swap question!!
Hey guys sup? Well idon't have a mitsubushi but i do love vr4's!! Yeah anyways...my friend has a dodge stealth es model.Its the really low class ones..very basic with roll up windows, cloth seats..u know? Well i told him he should through the vr4 engine in it.I know that the vr4 is an awd and the stealth es model is fwd.Well my question is that can vr4 long block bolt up to his stock tranny? Thanks!
The quick answer is "no it can't"
Resistance Is Futile (If < 1ohm) |
Re: Engine swap question!!
I have a 92 stealth es and I was thinking about an engine swap as well but I wanted to swap transmissions as well so that my gearing is right and I go from a 5spd to a 6spd. I figure I will need the tranny, engine and computer. Is there anything else I need OR is it even possible.
sincerely, -wondering in Maryland |
yes, you can swap in a vr-4 motor to bolt up to an N/A tranny. Is it a direct bolt on to the tranny? no, but there will have to be minor modification to fit. Bear in mind though, you will need other stuff to make it work as well. Be prepared to spend around 4 grand if your doing a whole motor swap.
As for the other question, yes you can put a 6-speed in a FWD along with a vr-4 motor, but you can't have AWD unless you look into spending lots of money to change the rear frame of your car. The basic idea is to weld up the VCU on the AWD tranny to run it as a FWD, but its a good idea to sell your good VCU to someone who needs it and let them give you back their bad VCU, cause you dont need it anyways, and there is a short supply of VCUs left, and there are VR-4 owners needing them.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition 1994 Mitsubishi 3000GT SL-TT Automatic - Black 3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods 1994 Mitsubishi 3000GT VR-4 - Black Intake & Boost Controller so far 2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods |
Since when does the MTX FWD tranny not bolt dirrectly to the TT engine? I could have sworn it bolted right up. That is not saying the engine swap will be that easy, but I thought the tranny was simple.
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions. |
Re: Re: Engine swap question!!
I believe your supposed to grind down something on the tranny to make it directly bolt on.
Re: Re: Re: Engine swap question!!
Only tranny that needs something ground down is the ATX if I remember right.
fantomdave, please please please stop reviving threads from 2002. If you have a question, just make a new thread.
96 3000gt vr4 -K&N FIPK -Proboost mbc -Cusco front + rear strut bars -Greddy type-s -ATR downpipe -no cats -15Gs, 3sx aluminum pulley, FMIC, SAFC, walboro pump, EVO 560ccs, and Meth Injection Kit all waiting to go in shortly. Your 1996 Mitsubishi 3000GT VR-4 is the 92nd out of the 315 that were made that year. Only 21 of which are exactly identical. |
