Old 02-19-2004, 01:24 PM
88zccivic 88zccivic is offline
turbo air filter
can you guys that are turboed give me some ideas on where to run a filter for my car. its a 88 4-door dohc zc and t25 turbo. it looks like it would fit nice right where the radiator overflow tank sits factory but im afraid it might catch some rain being behind the headlight?
any pics. or sugestions?
Old 02-19-2004, 01:34 PM
walt0023 walt0023 is offline
Send a message via AIM to walt0023 Send a message via Yahoo to walt0023
Re: turbo air filter
you can run it right where you are talking about but make a sheild out of aluminum to block any rain water that could enter but i dout any would.
Old 02-19-2004, 02:51 PM
redmanjd redmanjd is offline
i have mine where the battery tray use to be
95 b18b
new crank, eagle rods, je 10.5 : 1 pistons, 8lb flywheel, stage 3 act clutch, billet aluminium and urathane mounts, balanced rotating mass, 14.3 @ 93mph
New additions, teo4h turbo, ssautochrome turbo manifold, custom piping, turboxs bov, dsm 450cc injectors, greddy e-manage fuel controller 13.07 @ 107 untuned
Old 02-19-2004, 03:05 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
I would put it where my battery used to be (relocated battery to trunk).
Old 02-19-2004, 10:54 PM
i have my battery in the trunk but my intake side of the turbo is facing the drivers side of the car and i have the stock radiator so there isnt much room to run a pipe through i dont think do you have any pics?
Old 02-20-2004, 02:34 PM
ci5ic's Avatar
Re: Re: turbo air filter
Get rid of your radiator reservoir and put it there...
My reservoir fell out somehow about a year ago, and I haven't replaced it... Just make sure you've always got enough coolant/antifreeze in the radiator.
Old 02-21-2004, 12:13 AM
Hybrid1990crx's Avatar
your intake won't suck wanter unless fully submerged in water. so it will be fine where you want it. and if you still dont trust it, you can get a aem bypass vavle.
K&N Engine Air Filters - Worth It? RidingOnRailz Engineering/ Technical 9 06-24-2011 09:34 AM
Air Filter. Recommendations? xephornite Aveo 5 07-10-2010 05:42 PM
backfirea and caught air filter on fire!!!! davidrobert2 LeSabre 8 03-27-2009 07:22 AM
turbo... air filter? Derk_eliso Cavalier 6 04-20-2007 10:34 PM
2004 passat 1.8L Turbo Air filter change procedure valpon Passat 0 12-11-2005 08:16 PM
