Old 02-19-2004, 12:01 AM
patviper patviper is offline
Cavavlier RS V6 3.1 Coolant prob
Hi , I got a serious car trouble , i got a cavalier rs 93 v6 3.1 and my coolant keeps goin down every day , i fill it up in the morning and at the end of the day my coolant is empty ( in the white plastic container) that goes to the radiator. There's no sign anywhwere where it could leak and my heater seems to be loosing it's heat.Also to had to this problem ,there's a big smoke that come's out of my muffler kinda blueish , my oil stays full. My motor runs ok and the smoke does smell like prestone. Can somebody please help me !?
thanx
Old 02-19-2004, 01:54 AM
Mariano Mariano is offline
Re: Cavavlier RS V6 3.1 Coolant prob
If the smoke you see is white in color it could be your head gasket leaking antifreeeze into the combustion chamber. You should also check where you heater hoses go into the firewall. Gm used plastic ends on the heater cores and it seems they like to split after a while.
Old 02-19-2004, 04:48 AM
dxrflyboy dxrflyboy is offline
I've done a few head gaskets on 2.8 and 3.1 motors. Unfortunately, blown head gaskets are a common problem, due in part to the crappy machining of the engine blocks at the factory. I sand the block decks until the tool marks are gone and plane the heads whenever I have one apart.
tamiya lotus europa special teszion Completed Projects / Gallery 12 02-05-2012 12:41 AM
Oil Pressure 130 Pounds Smith1000 Park Avenue 10 04-18-2011 08:39 PM
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
