Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 02-18-2004, 06:34 PM
macklin1953 macklin1953 is offline
2004 Maxima Headlights
In the o4 you can adjust the headlight sensitivity, but the owners manual doesn't explain which direction 1-4 is more sensitive to what. Is 1 most likely to turn the lights on in dim light or is 4 more likely.
Old 02-19-2004, 10:05 AM
BP2K2Max's Avatar
BP2K2Max BP2K2Max is offline
Send a message via AIM to BP2K2Max
Re: 2004 Maxima Headlights
we're mostly 95-03 owners. if you go to forums.maxima.org you'll most likely get a response.
BP's Rides;
- 2005 Kawasaki Ninja ZX6R- Mods: ECU Jumper, Akrapovic Slip-on, Power Commander III, 8000K HID's.
- 2K2 Maxima 6 Speed-Mods: Advanced Timing, Cattman Cat-back Exhaust, H&R Springs, Tokico Illumina Struts, Konig Theory 19" Rims.
Old 02-19-2004, 12:24 PM
chrisr67's Avatar
chrisr67 chrisr67 is offline
try this: when it starts to get dark, pull your car in front of a wall, your garage, etc. turn the lights on and start adjusting. You should be able to tell by looking at the brightness of the lights shining on the wall. Adjust accordingly.
2004 LeSabre: How do I disable automatic headlights? Audire LeSabre 11 11-28-2009 01:05 AM
2001 Maxima Headlight Upgrade Nightwatch Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 13 12-08-2004 07:16 AM
2004 Maxima Headlight Aim Adjustment gmblr Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 0 09-03-2004 08:18 PM
replacing 2002 maxima headlight w/ 2001's bbee_w Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 18 07-21-2004 09:13 PM
97-99 OEM Nissan Maxima Headlight Headlamp infini-max Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 1 05-13-2002 10:34 AM
