Old 01-02-2002, 01:14 AM
VTECseoul VTECseoul is offline
Send a message via AIM to VTECseoul
does VAFC affect motor stability?
when using a VTEC AFC controller, i've read that if you set the VTEC crossover point too low, that the car won't run good. if true, why? isn't the VTEC lobe just a higher cam profile, right? how does activating VTEC early affect engine performance?
2000 Honda Accord LX Satin Silver Sedan
AEM ColdAirIntake
Neuspeed Sport Springs
Nitto 450 225/50
Prime Racing M8 17x7
S15 vs AE86 - 2006 HotWheels Touge
Old 01-02-2002, 01:12 PM
drift's Avatar
drift drift is offline
Send a message via AIM to drift
activating at too low of an rpm can reduce low end responsiveness due to the high lobe profiles of the VTEC lobe. like a high lift cam in a V8, sometimes too much flow is not good, especially at low rpm.
also, VTEC operates on oil pressure. all Hondas generate more than enough pressure for proper VTEC activation, but at low rpm, oil pressure is obviously lower as the pump is crank driven. in rare cases, VTEC may fail to activate due to low oil pressure.
the bottom line is low rpm response... setting the crossover too low will cause the car to perform poorly at low rpm after VTEC crossover
Old 01-04-2002, 01:19 AM
that makes sense. i tried to relate to it like that, but my imagination couldn't see it...now i can, THX.
AEM ColdAirIntake
Nitto 450 225/50
how much does mileage affect performance on wrx? nimkip Impreza/9-2x/Outback Sport 1 09-22-2004 05:31 PM
How much does octane affect HP? lookin4luey Camaro Discussions 33 08-23-2004 03:15 PM
How does AC affect gas mileage? 90gs Integra 7 06-01-2003 09:21 PM
Does shock affect the ride height? khead717 Tires and Wheels 9 01-09-2003 09:14 PM
does backpressure affect top speed? strodda Engineering/ Technical 3 09-28-2002 11:45 PM
