Go Back   Automotive Forums Car Chat > Honda > Integra
Old 05-27-2003, 07:14 PM
90gs's Avatar
90gs 90gs is offline
Send a message via ICQ to 90gs
How does AC affect gas mileage?
how many miles to the gallon do you lose from using air conditioning on a 90 integra 5spd?
i moved my air filter to my intake manifold and that almost made my miles to the gallon 1/3rd as much (ran way rich cuz the air was so hot, couldnt get enough air) so i moved it back... it was so much more throaty way back there though, i miss that noise
Old 05-27-2003, 07:24 PM
PWMAN's Avatar
PWMAN PWMAN is offline
With running it full blast I usually get about 5 less MPG.
Old 05-27-2003, 07:44 PM
sameintheend01's Avatar
sameintheend01 sameintheend01 is offline
Send a message via AIM to sameintheend01
from what i hear (maybe not correct) you actually get better milage on the freeway (freeway speed --not necessarily no the freeway for us SoCalers) with the a/c instead of the windows rolled down.
Clear Corners
Front and Rear Strut Bars
Cold Air Intake with K&N filter
Iridium Spark Plugs
High Performance Plug Wires
High Flow Cat (unistalled)
Cool high/low beam lights
All around slotted and AEM pads
Old 05-29-2003, 01:25 AM
90gs's Avatar
i usually have it on 2 clicks out of 4 if i use AC
how much horsepower does 2 clicks of just fan, no AC.. what about 3 or 4 clicks?
i have my windows down a lot and it bogs a LOT more with the AC on and windows up compared to windows down
Old 05-29-2003, 01:54 AM
doesn't matter how much the fan is on with the a/c. The a/c works as either on or off like that (compressor clutch is engaged or not). On some cars, if you take the temp. switch all the way down, the a/c will stay on no matter what. I keep my temp a little bit above that just in case. Other cars just mix hot hair with a/c depending on temp. position.
Clear Corners
Iridium Spark Plugs
Old 06-01-2003, 04:36 PM
90gs's Avatar
does just regular fan affect mileage? i heard it takes away a few HP while using it
Old 06-01-2003, 06:21 PM
it shouldnt be anything noticable. It is electric. I know that electric radiator fans use only a couple horsepower and the blower has to use less than a 1/4 of the power of the radiator fan since it si much smaller.
Clear Corners
Iridium Spark Plugs
Old 06-01-2003, 09:21 PM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
I lose about 2 mpg with the a/c on my 91 civic lx with a sohc zc engine. Normally I get about 30 but now that its summer and I use that shit on the way back from school (40 miles) I get 28 mpg
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
