Old 02-17-2004, 10:03 PM
annointed annointed is offline
Send a message via AIM to annointed Send a message via Yahoo to annointed
using timing light on '88 Civic 1.5L hatchback?
I need to run my '88 Civic hatchback through emissions/inspection, and just got a basic timing light today (I had to change the distributor since buying the car to fix a drivability issue). It seems to run great, and gets 37 mpg, but I don't want to take any chances, so I would like to set the ignition timing using the timing light.
Any advice? Its snowing today, and I haven't even had a chance to look at the crank pully area for marks, etc, but I assume this should be straightforward. Also, what is proper advance at idle for this car?
Its a 1.5L '88 Civic, fuel injected, 4 speed manual.
Thanks,
Mark
'02 Subaru WRX - 326 whp/320 ft-lbs
'94 Subaru Impreza L AWD w/jdm WRX motor [email protected] (14 psi)
'91 Nissan 240sx (soon to be Silvia )
'88 Honda Civic hatchback 1.5L of NA fury
Old 02-17-2004, 10:33 PM
rosshatch89 rosshatch89 is offline
Send a message via AIM to rosshatch89
Re: using timing light on '88 Civic 1.5L hatchback?
to hook up the timing light just connect the battery to the light and put the clip on the #1 plug wire if your looking youll see the marks theres 3 of them other than the tdc one and i think mine was like 11 degrees not positive
Old 02-17-2004, 10:36 PM
oh yeah forgot the way you line it up is from the top you just look straight down and on the timing belt cover should be a little tab
Old 02-18-2004, 12:37 AM
Re: Re: using timing light on '88 Civic 1.5L hatchback?
Basically, I just want to know which tab to line it up with (red I assume?), and how many degrees of advance the d15 is supposed to run at idle.
Also, I assume I have to disable the ecu's timing control...if I read correctly, that's probably why you jump that loose connector on the left side strut area in the engine bay (on '88/89 MY's).
Old 02-18-2004, 08:20 AM
Spider151 Spider151 is offline
Timing not required
If you are getting 37mpg and it runs smooth, unless your cat is blown, you will pass smog. I have an '88 w/ all original sensors and cat but a SOHC ZC in it. It _still_ passes smog and I get about 27mpg. You are going to be fine.
tamiya lotus europa special teszion Completed Projects / Gallery 12 02-05-2012 12:41 AM
Oil Pressure 130 Pounds Smith1000 Park Avenue 10 04-18-2011 08:39 PM
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
