Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 02-17-2004, 05:54 PM
Randaljag Randaljag is offline
coolant loss
New member. I have a 98 Sierra with a 305 and it sems as though I'm always adding coolant. A buddy has a 97 and has the same problem. He's a pit crew chief for a race team and he doesn't seem to know what is causing the coolant loss. I've been reading the posts on coolant loss on other vehicles...was wondering if anybody else has had this problem with their GMC.
Old 02-17-2004, 06:07 PM
xjoeharperx xjoeharperx is offline
Send a message via Yahoo to xjoeharperx
Re: coolant loss
head gasket
Old 03-06-2004, 11:48 AM
70camaro 70camaro is offline
Re: coolant loss
Not head gasket, intake gasket... This is a common problem with these, mine too. You can either replace the gasket or keep filling the coolant, but be sure to check your oil and make sure your not gettin coolant in the oil.
Old 03-06-2004, 01:36 PM
dcammata dcammata is offline
Re: coolant loss
My truck had a similiar problem and it was a 14 dollar part. It was a line fitting that screwed into the intake and the intake hose clipped right into it. It was leaking on my truck and the coolant would run along the valve cover making look like an intake leak but it luckily it wasnt. I hope you have the same luck. Cheers
Old 03-13-2004, 09:21 PM
jrrocque jrrocque is offline
I have a 99 Sierra. The Low Coolant light came on about a month ago. I did some research on it and found out that some Sierra's have a radiator with plastic end caps on it and some do not. Ones with the plasitic end caps tend to run hotter than normal and may over heat and or loose coolant due to evaporation. I have the plastic end caps on mine and so far I have not had any more problems since I added some coolant.
3.8 coolant loss help lesabre LeSabre 21 12-23-2005 02:55 PM
2000 grand caravan mystery coolant loss rykerjenbob Caravan | Voyager 3 01-22-2004 02:58 PM
coolant loss Chad S. X5 1 11-23-2003 02:50 PM
previa coolant loss gap Previa 1 08-19-2002 03:46 PM
Coolant loss geoff200 Maintenance 6 07-23-2001 05:01 PM
