Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 02-17-2004, 04:47 PM
soccmid soccmid is offline
Send a message via AIM to soccmid
my lude is sick :(
help. my lude is sick it has been for a while but because i drive it so little it wasnt a big deal but now i have to drive it. i took it to emissions and i failed miserably (passin is 1.00 and i was at like 5.034) on hydrocarbons which is just unburnt fuel. i need some ideas of what may be wrong. i have a black residue on my tail pipes that tends to cake up if i do not clean the tail pipes. heres a list of what i have done to try and fix teh problem
new pcv valve
new sparks
new distributor case and rotor
new intake head
changed my oil and my tires ( jus fyi wasnt smart went to emissions with bad tires and dirty oil)
Thats all i have done so far. any advice or comments r welcome
"You can't do anything worth doing in life without taking a chance" - me
funny shit
Old 02-18-2004, 10:13 AM
AcesHigh's Avatar
AcesHigh AcesHigh is offline
Prelude Guy
Send a message via AIM to AcesHigh
Re: my lude is sick :(
Two words: Catalytic converter.
1993 Mazda Rx-7 Touring
Ricer Extraordinaire
Old 02-19-2004, 01:53 PM
any other ideas i kno little of this cars history as far as whats been replaced. im gonna take a look at the cat when i change my oil in a week or so any other ideas. btw thanks ACES
funny shit
Old 02-19-2004, 02:01 PM
FDTT FDTT is offline
What year lude do you have?
If you are running a carbed lude then you could have a leaky jet, mixture is to rich.
If you got a FI then you could have a cat problem but i dought it cause even without a cat you would not register that high in HC. I think maby you have a leaky injector. But deffinetly a fuel delivery problem. I know that Preludes generly run rich so i guess that it is possible for the cat to be at fault but i find that very unlikley.
Dont drive faster than your angels can fly
Old 02-19-2004, 03:34 PM
thanks . . . new update when i changed my spark plugs they were black and brown and smelled like gasoline. so something is defitnely wrong . im losing fuel economy and damn power iwth this problem. i must eb running rich/ have a FI prelude jus to let u kno 92 si
funny shit
Old 02-20-2004, 12:33 AM
AcesHigh's Avatar
Prelude Guy
What kind of plugs are you using.
Old 02-20-2004, 08:52 PM
my odl ones were ngk but now i have bosch plugs. the ngk were defintely brownish and smell of gasoline. thanks a lot u guys
funny shit
Old 02-22-2004, 10:50 AM
help please jus tryin to get an idea
funny shit
Old 02-22-2004, 11:11 AM
AcesHigh's Avatar
Prelude Guy
You are burning too much gasoline. Mine were the same when I used Bosch +4 plugs. Switch out to some colder plugs for awhile, and try some fuel injector cleaner solution in your gasoline. See if that helps.
Old 02-22-2004, 08:42 PM
thanks aces u been helpful . i tried some otehr sparks and ive run like 4 fuel injector cleaner thinsg thru it but nothin helpin major. imma take off eth fuel rail and get a look at teh injectors to chek emm out. this sux my car is slower than focuses
funny shit
Old 02-24-2004, 01:40 AM
Stereo Stereo is offline
Send a message via AIM to Stereo
is your check engine light staying on? if so it could be somthing wrong with one of the sensors like the map sensor or coolant temp sensor even a sticking injector also use only Nd or NGK plugs on your car the autolites and Bosch plugs don't work too well in hondas
Old 02-26-2004, 11:03 AM
hondaprelude88 hondaprelude88 is offline
O2 sensor if its fuel injected these get gumbed up and make the car run extreamly rich. Just a thought.
Old 02-26-2004, 01:49 PM
i cheked out all teh sensors today and the cat. all look fine my buddy joe has a shop with an emissions diagnostic testing machine. im jus gonna let him take a look at it. hopefully it will know.
funny shit
Old 02-26-2004, 03:38 PM
SBallerk2 SBallerk2 is offline
Send a message via MSN to SBallerk2
R u guys kidding me I just got Bosch +4 spark plugs and replaced my stocked NGK (which i'm guessing we're never replaced) but they didn't look so nasty they had normal black around the plug i guess but i threw the plugs away (NGK) r Bosch +4 spark plugs that bad? please give reason's if they are? should I replace them even thou there about 3 days old? and i'm thinking of buying the wireset too which r some good one's? thankxxx guys...sorry soccmid i ain't got a clue what could be wrong with ur car...
Old 02-27-2004, 09:29 AM
Re: Re: my lude is sick :(
I am standing beside this that its not your plugs, they have nothing to do with weather a car is running rich or not. I would check out things that have to do with fuel control. The plugs are fine.
What's the difference between a base lude and an sh lude? Lingerie_Ripper Prelude 17 06-09-2004 11:04 PM
5G lude front clip on 3g lude white97ex Prelude 0 06-24-2003 06:33 PM
Gsr Dash, Sick Sick .... SIvic '88 - '91 Civic | CRX | Wagon | Shuttlee 12 03-29-2003 06:37 AM
