Old 02-17-2004, 10:10 AM
dhardison dhardison is offline
'99 Silverado factory wheel width
I have a '99 Silverado with factory aluminum wheels. Can anyone tell me the width of those wheels? Also, I've seen where 285s will work on factory wheels, will 305s work ok as well?
Thanks,
Dan
Old 03-30-2004, 11:05 PM
mjgjr72 mjgjr72 is offline
Re: '99 Silverado factory wheel width
have 2000 factory aluminums are 7 inch , 285 are factory opional size , 305 may not clear in front without suspention, or body lift.
Old 03-30-2004, 11:23 PM
chevytrucks92's Avatar
chevytrucks92 chevytrucks92 is offline
I think the only problem you would have with 305s would be the clearance when you turn the wheels. They probably will rub when you cut the wheels so you would have go with some kind of spacers or something. Height wise,there is only about an inch difference in 305s and 285s (depends on the brand of the tire) but the width is a little more then an inch.
**1966 Chevy II**
355 SBC, Turbo 400, 5.13 gear, IHRA Certified to 8.50 in the 1/4
Last Race (10-6-07) So its been awhile...
Dial: 6.77, RT: -.0001, 60': 1.4360, 1/8th: 6.7942 @ 100.65 mph
Fastest Pass of '07 (10-6-07)
60': 1.4360, 330': 4.3453, 1/8th: 6.7942 @ 100.65 mph
25 and in BIG TIME Debt Crew member #2
Deuce's Wild Racing: Take a Ride on the WILD SIDE
Old 03-31-2004, 07:31 AM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
At the tire shop whre I used to work, 305's will work on a factory rim, you just need to crank the torsion bars at least 4 rounds. Even then they may still hit on the front air dam at full turn. If you trim this a little with a razor knife, it should solve your problem. Now if your considering using 10" wheels, they will hit under the fender, and on the air dam as well. This requires some cutting, bending wiht a hammer under the fender..etc....THis is with only 285's. I have no idea what 305's would do on a 10" wheel.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
'99 Silverado 2500 - Replace rear wheel bearing bheston Silverado 5 11-09-2010 02:07 PM
Wheel width/offset help Rooster32 Interior | Exterior | Appearance 0 04-05-2010 10:45 PM
wheel width on tracer LTS alloy wheel Mattyg2 Tracer 0 04-12-2007 06:37 PM
How to match tyre-wheel width ekms2 Tires and Wheels 1 05-01-2003 03:13 PM
wheel width max on eclipse? EliteImports Exterior and Wheels 2 01-20-2002 05:14 PM
