Old 02-16-2004, 08:51 PM
King Cobra 22 King Cobra 22 is offline
Is this car in the 12's with this combo?
1990 LX hatchback no front swaybar, 4bangerfrnt springs, fiberglass hood, stock bottom end, synthetic lube, stage 2 trickflow cam, cloyes timing chain, home ported E7's, crane springs, 24lb/hr injectors, GT40 intake, 70mmTB, 80mmMAF, 9" K+N filter, BBK shortie headers, BBK offroad h-pipe, 2chamber flows w/dumps, No EGR or any other emissions equipment, eng turns water pump and alt. only with underdrive puleys,3500 stall TCI AOD with B+M shift kit, 4.56 gears, rebuilt posi, skinnies,aluminum wheels MT 28"x10" Sportsman "I" tires, no jack, spartire insulation etc.
12 second 1/4 mile???
Old 02-18-2004, 04:00 PM
daveshapellSVT's Avatar
daveshapellSVT daveshapellSVT is offline
Specvgini
Re: Is this car in the 12's with this combo?
i's say so..
2002 Mustang GT ( 4:10 gears, X pipe, cat back, CAI, Under drive pulley set, Intake plenum, throttle body, Tuned) 13.7@101mph https://youtu.be/btMHZeoZTS0
https://www.youtube.com/channel/UCeu...PX2WMqty2z4aPw
2015 Jeep renegade trailhawk
2017 VW Jetta TSI 1.8T
Old 02-18-2004, 05:30 PM
WhiteCavaliac WhiteCavaliac is offline
Send a message via AIM to WhiteCavaliac Send a message via Yahoo to WhiteCavaliac
I would fell better about saying 12's if your E7 heads where aluminum trickflows (or something much lighter/better flowing) and if your had some anti-wheelhop components in the rear like shocks,springs,upper/lower control arms. The stock components are barely enough for the stock horsepower, so imagine.
Old 02-18-2004, 06:23 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
Doubtful wit E7 heads, no rear suspension work, and M/T Sportmans I aren't full slicks either i believe?
I'm thinking more mid 13's with a really good launch.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 02-18-2004, 11:33 PM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Going to have to second this post!
Ditch the E7's!
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 02-19-2004, 08:10 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
Re: Re: Is this car in the 12's with this combo?
Ditch the E7's!
Dido!
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 02-27-2004, 03:53 PM
Matts50's Avatar
Matts50 Matts50 is offline
Send a message via AIM to Matts50
I think 12.99's are possible with that set-up. But on the other hand I think your combo could be better matched up in some areas. For example, 80mm MAF is pretty big on your set-up and is probably killing you down low IMO.
Matt
Gears n Exhaust = Slow
