Old 02-16-2004, 07:35 PM
Joseph1082 Joseph1082 is offline
Send a message via AIM to Joseph1082
Pully Question
Do pullies have any negative affects?? Do they supply enough power to your accessories
Old 02-16-2004, 07:42 PM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
Re: Pully Question
if you get the complete set then they run fairly well. you shouldnt get underdrives if you have a pretty big sound system, but for the most part i have never heard anything seriously negative from someone who had underdrive pulleys...
Old 02-16-2004, 08:38 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
Re: Pully Question
yeah, the only side effect is the chance of lowered charging from the alternator, so if you have a big stereo system or high current draw from accessories, then at least keep the stock alternator pully. you can do the other ones for a few more hp.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 02-16-2004, 08:43 PM
Re: Pully Question
I was looking at the March set, so this should be good, but i want to add 2 12s later on, will that be a problem
Old 02-16-2004, 08:54 PM
89IROC&RS's Avatar
Re: Pully Question
no amp? it all depends on the current draw of the amp your putting in. you wont be able to power 2 12's off a head unit, youll need an amp. like i said before, if you leave the alternator pully alone, and keep the charge, and you have at least a 105amp alternator, you should be fine.
Old 02-16-2004, 10:01 PM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
hmm 105 amps on a 12v system
Wattage=voltage x intensity
Wattage= 12 x 105
Wattage = 1260 watts max.
No point in this. Just thought it would be cool
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
Old 02-16-2004, 11:50 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
Re: Pully Question
get a higher output alternator...
and a Blower of course.
Old 02-17-2004, 10:17 AM
Re: Pully Question
So i can't use the complete pully set if i plan to have an amp? BTW i thought 2 12s automatically meant amp, cause what else you gonna power 2 12s with
Old 02-17-2004, 03:52 PM
Re: Pully Question
now wait a sec, if he doesnt get the alternator pulley would that kindof high gear the alternator in a way. this is just me thinking off the top of my head, but if the crank pulley is smaller and the alt pulley stays the same the alt pulley would slow down more cause the ratio has changed. i thought the point of getting both was to keep the ratio the same so that the pulleys would turn at almost the same speed as stock. again someone let me in on this, just thinkin off top of my head...
ingnition problem and pully question LTTL Escort 10 07-22-2007 12:57 PM
underdrive pully question ABigWeaney Engine, Transmission and Drivetrain 1 04-05-2007 01:10 PM
? Pully Question ? Cimadomo Grand Prix 2 06-15-2006 12:03 AM
pully question rob04gtp Grand Prix 13 06-07-2005 01:37 PM
Tension pully question... diezelman Grand Prix 11 03-09-2005 11:30 PM
