| Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines. |
my 2000 I30 makes a fart noise by my glove
how do i fix that?
also, i need the instructions to program my keyless remote thanx |
Re: my 2000 I30 makes a fart noise by my glove
Reprogram Key Fob
QX4, 1997-2004 Q45, I30, I35,1999-2002 G20, FX, G35, M45 To reprogram (enter new ID) key fob (keyless remote controller) follow the steps. 1. Close all doors and lock all doors 2. Insert and remove the key from the ignition key cylinder more than six times within 10 seconds. (The hazard warning lamp will then flash.) Note: Key should be withdrawn from ignition key cylinder completely each time. 3. Insert key on ignition key cylinder and turn ignition key switch to "AAC" position At this time, the new ID code is entered and original (previous) ID codes are erase. 4. Push any button on the new remote controller once. (The hazard warning lamp will then flash) If there is only one remote controller skip step 5. 5. Additional ID code entry Release the door lock, then lock again with door lock/unlock switch (In power window main switch) 6. Remove key from ignition 7. Unlock driver side door, open driver side door and then close the door. (END) Note: -If you need to activate more than two additional new remote controllers, repeat the procedure on step 5 "Additional ID code entry" for each new remote controller. -Entry of maximum four ID codes is allowed and any attempt to enter more will be ignore. |
