Old 02-16-2004, 06:58 PM
Black_Wido_Talon Black_Wido_Talon is offline
Send a message via Yahoo to Black_Wido_Talon
Angry My ignition fuse keeps blowing out in my 91 talon
i was driving one night and all of a sudden my car died i checked and discoverd it was the ignition fuse beside the battery so i changed it and after 4 or 5 starts it starts to burn up again and so i riged up the fuse with a thin piece of wire so if it got hot again it would burn up and one day the car quit it turns over but no dice i checked the EFI relay and its good and i used the direct fuel pump check behind the battery still no dice so i think i need a new fuel pump and i checked the ECM and there is no dice there either nothing at all. I am confused and am ready to burn it were it sits.
Old 02-22-2004, 09:37 PM
bigpula bigpula is offline
Re: My ignition fuse keeps blowing out in my 91 talon
If the car turns over, starts and dies right away you might want to check the crank angle sensor. It should pop up a code 22 or a 23. (CAM and Crank sensor should be the same) If you need one I have one.
Old 03-07-2004, 07:27 PM
it was my damn fuel sending unit it was crossing over some how like a live and ground touching i got a used one for $150 with a fuel pump but i am going to be looking for another one because the little main sending neck broke at the base and its spitting out gas so i riged it up
ignition fuse keeps blowing. cwetherington Stratus 18 09-08-2015 05:07 PM
PLZ help 94 grand am ignition fuse keeps blowin! thewizard67 Grand AM 7 05-03-2014 07:46 AM
95 mx6 - ignition fuse keeps blowing out markofcain MX-6 0 08-17-2006 02:27 PM
Help Please I Dont Want To Buy Another Car!! Ignition Fuse Keeps Blowing!!!! 94parkaveultra Park Avenue 5 03-11-2005 09:30 AM
Ignition fuse keeps blowing ryanm75 M Bodies 1 12-04-2004 01:13 AM
