Old 02-16-2004, 06:36 PM
deemoney deemoney is offline
Angry oil on my spark plug cable
Today i look at my spark plug cable and it had oil. The car is riding the same.Is it serious and how much will it cost me.
Old 02-16-2004, 09:55 PM
rosshatch89 rosshatch89 is offline
Send a message via AIM to rosshatch89
Re: oil on my spark plug cable
you mean plug wire? if it was just oil on the outside you probably just have a leak somewhere may want to clean your engine and run it and just watch if you dont see anything leaking bad then drive it for a day and you should be able to find your leak
Old 02-16-2004, 10:45 PM
91zc 91zc is offline
Depends where the oil was located. If it was on the boot that slips over the spark plug then your spark plug tube seals are leaking. They are very simple to replace. All you do is remove the valve cover and remove the old ones from around the tube and replace them with new ones along with a new valve cover gasket. It is really a very simple project.
91 civic 4dr
b16a
14.8@94
spark plugs freakyfire05 ZX2 2 02-17-2009 11:03 AM
96 caravan Having trouble with spark plug cable jakmehard Caravan | Voyager 4 01-04-2004 10:16 AM
high idle after spark plug/cable/distributor cap change gruvytune Dakota 0 07-13-2003 11:10 AM
