hookup please help
Hi, i just go the indiglo (luminescent Gauge Kit) for my 92 prelude. want to install it, but don't know how to take out the dash. Please help!!!
Thank you. |
Re: hookup please help
get a helms, haynes, or chiltons manual and follow the instructions. |
its super fun
well its a touch hard to explain in words. but i can give you a general idea.
1. remove the tweeter covers on each end of the dash. 2. pull the rubber striping located at the bottom of the gauges. off starting with the end (you'll see the end of it after step 1) 3. remove the 8 or so screws that hold the long black piece to the underside of the upper dash lip. (you need a stubby phillips for this.) 4. just to the right of the speedo you will see a vertical piece of black trim held in with a screw. remove it. 5. now there are screws on either side of the speedo/tach bezel that can be removed. (either 2 or 4, cant remember) 6. carefully negotiate the bezel out of the dash. reach around and unclip any harnesses. now you can take the bezel out of the car and take it apart. I think you can figure that part out. 7. there are two little set screws on the gauge face that need to be removed, then slide your faces on and reset the screws. bam your done. hope that helps
