Old 02-14-2004, 09:31 PM
alphalanos alphalanos is offline
Home made strut bars
could i just get a peice of pipe, cut it and then make some brackets, weld it together then bolt it in? it will work as long as the pipe is very stiff and the brackets are tight wont it?
Old 02-14-2004, 09:51 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Do you mean a brace for the top of the strut towers?
Home mead is fine. I have seen folks use 1 inch square section tubing, thick wall, like .125 inch and it works fine If its under the hood, try a triangular brace between both towers and the firewall, if there is room and a solid mounting surface.
strut bar recommendation dpj52190 Corolla/Matrix/Voltz 1 01-09-2011 10:50 AM
is a strut bar just a strut bar? toronto pimp '88 - '91 Civic | CRX | Wagon | Shuttlee 36 07-22-2003 10:35 PM
!for Sale! Custom Made Aluminum Front Strut Bars SUPERMAC Lancer 0 07-08-2002 03:11 AM
!for Sale! Custom Made 2002+ Lancer Aluminum Front Strut Bars SUPERMAC Lancer 0 06-29-2002 11:46 AM
