Old 02-14-2004, 05:01 PM
jdmhotrod's Avatar
jdmhotrod jdmhotrod is offline
Banned
help with tamiya clear coat
i spray it over the top of my impala witch has been painted with plasti-kote auto paint and i let it dry for 24 hours and i sprayed a clear on it using tamiya clear and it turns out flat not evan a hint of gloss, isent tamiya clear compatable with auto paint if not should i use testors laquer clear(i have had good results with it). the only reson i quit useing testors laquer clear is because it takes to long to dry like 2 weeks and tamiya on the other hand takes only 24 hours. can anyone help? thanks.
Robert.
Old 02-14-2004, 07:34 PM
Vric's Avatar
Vric Vric is offline
Re: help with tamiya clear coat
look like an incompatibility with enamel and laquer.
if you choose to use testor clear (the only pray can I use sometime from testor) use the one with the serial 18xx. other will give you really bad result, and once you used it 2 time, trash it eve if there is some left.. there is not enugh pressure in the can for more than 2 use (3 at the most)
also don't put too much of clear, it yellow over time and if you put too much, it will look really bad
Old 02-14-2004, 10:10 PM
jdmhotrod's Avatar
Banned
yea i know about testors, actually the plasti-kote auto paint is a laquer. but i just went out and bought some plasti-kote auto clear so i hop it will work.
Old 02-14-2004, 10:22 PM
freakray freakray is offline
AF Modelrater
Like I told you elsewhere Robert, you shouldn't have a problem with same brand over the same.
Testors clear from Walmart is enamel, they don't sell the Testors lacquer clear at Walmart.
Old 02-14-2004, 10:48 PM
jdmhotrod's Avatar
Banned
thanks ray youv been a very big help.
Robert.
Old 02-14-2004, 10:54 PM
jswillmon's Avatar
jswillmon jswillmon is offline
Send a message via AIM to jswillmon
jdm you have a pm
tamiya lotus europa special teszion Completed Projects / Gallery 12 02-05-2012 12:41 AM
