Old 02-14-2004, 10:31 AM
F-106 Delta Dart F-106 Delta Dart is offline
Transmission Cooler-Which coolant line?
2001 S-10 My truck did not come with the optional automatic transmission cooler. I want ideas on the best way to go. Can a person go to the dealer and buy the factory outfit? Best reason for doing this would be all the cooler lines would be a simple installation. If this can't be done I would want to go with the stacked plate type of cooler(B&M-Fluidyne-etc.
). I would want to install the cooler after the radiator. With this setup which cooling line goes from the radiator back to the transmission? Any info that you could give would be a big help! Thanks for your time.
Old 02-15-2004, 02:30 PM
movin2stereo's Avatar
movin2stereo movin2stereo is offline
Re: Transmission Cooler-Which coolant line?
The top line is the return.
Old 02-17-2004, 11:50 PM
tommie99 tommie99 is offline
Send a message via Yahoo to tommie99
the best way is to install the cooler before the radiator just pick up a after maket cooler it comes with hose and it does not matter witch hose goes where (top or bottom) its esy to install plus it will give more life to your trans. the reason i said before the radiator it gets more air and its easy to install .......................tommie99
Old 02-18-2004, 12:55 AM
TopDogg TopDogg is offline
Yo YO I think when he said he wanted to install after the radiator he meant install it so that the fluid enters the cooler after it exits the radiator for maximum cooling.
Summitracing.com will hook you up with the one you need. You can browse through many of them and read some specs. If your still not sure just send an email to their tech department. Save money this way. I couldnt imagine what the dealer wants to install a factory one.
Old 02-18-2004, 05:21 AM
Yes exactly.The top line is the return,meaning the fluid exists the radiator cooler and returns to the tranny.
Lower Radiator Hose Removal, with Transmission Cooler lines blazerchase S-10 1 08-29-2010 03:56 PM
AFT fluid in coolant issue mataliandy '01-'05 Civic 2 08-11-2010 09:51 PM
Trouble with oil cooler lines marshallblazer Problem Diagnosis 2 03-11-2010 08:37 PM
flow direction of tranny coolant lines & add a tranny cooler stevenf12801 Caravan | Voyager 1 09-12-2007 08:43 PM
Transmission Cooler, Which Line is Which? G202Go Accord/TSX/Accord Hybrid 6 02-03-2004 12:56 PM
