Old 01-26-2004, 04:02 PM
G202Go G202Go is offline
Transmission Cooler, Which Line is Which?
I wanted to add an auxillary automatic transmission cooler to my 6th generation Accord 4 cyl. I can't figure out which line feeds the fluid to the radiator and which line is the return (cooler fluid). I did a search and couldn't come up with the answer. Does anyone have any idea which line is which? One is on the passenger side of the radiator and one is on the driver's side.
Old 01-26-2004, 04:11 PM
BullShifter's Avatar
Re: Transmission Cooler, Which Line is Which?
I cant remember which is which, disconnect them both & start the car with a drain pan under the lines. Only run it until you figure which is which - 30 seconds max, I would hope.
Old 01-27-2004, 08:44 AM
I don't think that would be a good idea since you'd be running the pump dry on one side. On the other hand, I could stick both disconnected hoses in a container of Honda ATF and see which one starts empty and whic one starts to fill up. Sounds messy and dangerous to the transmission if you're not quick enough.
Old 01-27-2004, 03:38 PM
That's why I said 30 seconds max, it should take 1 second to figure it out . . . .
Old 01-27-2004, 05:05 PM
accordztech accordztech is offline
Send a message via AIM to accordztech
it will take no more than 10 seconds to find out trust me i know...
www.cb7tuner.com <---90-93 accord board
:for sale: left and right motor mounts for 4th gen accord. great condition
:strut bar, rear..no brace...
Old 01-28-2004, 01:31 PM
I think I found the answer here. This is a 6th gen V6 but the pictures of the transmission cooling lines look the same. He hooked up his cooler to the driver's side hose. Later on because of the freezing temperatures, he switched sides.
6th Generation Trans Cooler "How To"
Old 02-03-2004, 12:56 PM
FWIW, I confirmed that the transmission cooler return line (cooled fluid) comes out on the driver's side of the bottom of the radiator.
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
