Old 02-12-2004, 11:53 PM
Jay eS Iye's Avatar
Jay eS Iye Jay eS Iye is offline
Send a message via AIM to Jay eS Iye
clicking/ticking noise from suspension
whenever i have the wheel turned all the way to the left, i hear a clicking noise coming from the driver's side wheel. I have however recently (like a month or so ago) replaced the axles and outer tie rods. what else could this be?
The Civic is gone...
The Camry never ran...
The Chevy is here to stay...
The Ultimate Honda Engine
Old 02-13-2004, 12:39 AM
Cjz89civic's Avatar
Cjz89civic Cjz89civic is offline
AF Premium User
Send a message via AIM to Cjz89civic Send a message via Yahoo to Cjz89civic
With out a doubt it is your C/V shaft(s) that are bad. Change them and you will lose the noise.
Mods: D16Z6 Turbo'd P28 ecu and Greddy emanage for fuel. FWD tire smoker
My first Civic love Died from 92 year old Fart not watchin out.
Old 02-13-2004, 08:23 AM
viper_2_4's Avatar
viper_2_4 viper_2_4 is offline
Send a message via MSN to viper_2_4
Re: clicking/ticking noise from suspension
thats what I am doing this weekend, except for me its the left side one (clicks on right hand turns)....not a hard job, more dirty than anything.....
Old 02-13-2004, 03:15 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
If you just replaced your axles, then the cv joints shouldnt be bad. Check though to see if your boots around your cv joints are torn at all.
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 02-13-2004, 07:09 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
you probably didnt tighten the CV shaft nut enough. i had a car come to my shop once that had that problem. the guy tried to do them himself, but didnt tighten one of the CV nuts enough and it clicked when turning at a certain degree.
edit: this is with brand new CV shafts, remember. and everything on the suspension was in good working order. its just something to check, make sure your bolts and nuts are tight
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 02-13-2004, 07:22 PM
CZ-R's Avatar
CZ-R CZ-R is offline
Send a message via AIM to CZ-R
However, is there any warranty for the axle/cv joint you just replaced? I've replaced both of my axles & the new ones had 30 day replacement warranties if for some reason they were bad.
Old 02-15-2004, 07:57 PM
Jay eS Iye's Avatar
yeah they have a warranty. i'll go check the bolt, but how do i check it? should i just go try to tighten it more?
Old 02-15-2004, 11:48 PM
EF You's Avatar
EF Life Giver
i would, just get a 32mm socket and impact and tighten it a bit. id bet it tightens
99 Sunfire GT 2.4L Twin Cam Auto--CLICKING NOISES FROM ENGINE BLOCK E. Frank Cavalier Problem Diagnosis 8 07-28-2009 07:25 PM
Ticking noise from engine norad M Bodies 5 07-02-2005 11:46 PM
Clicking / ticking Noise from engine HELP!!!!!! jkeness Sportage 1 12-16-2004 01:56 PM
Ticking noise from engine? Help! Zaius 3 Series 2 09-27-2004 11:56 AM
Ticking Noise from lower front of engine superranger92 Ranger | Courier 2 10-29-2003 04:20 PM
