Old 02-12-2004, 07:50 PM
benchph benchph is offline
Send a message via Yahoo to benchph
Talking squeaking brakes after driving hard.....
peeps,
my front brakes are squeaking when i step on the brakes...the sound is like "eek..ekk..ekk..ekk. ." btw my pads are quite new and i just had my rotors refaced a month ago...
helppppppppp
Old 02-12-2004, 08:04 PM
blindside.AMG's Avatar
blindside.AMG blindside.AMG is offline
Send a message via AIM to blindside.AMG
Brake noises are hard to diagnose over the internet. I say remove the wheels and see if one of the backing plates is hitting the rotor.
Old 02-12-2004, 09:02 PM
freakonaleash1187's Avatar
freakonaleash1187 freakonaleash1187 is offline
Send a message via AIM to freakonaleash1187 Send a message via MSN to freakonaleash1187
Re: squeaking brakes after driving hard.....
another thing that i have had wrong before was that my brakes were dirty. after a couple of days they cleaned themselves off and the squeaking went away.
ZedEx Crew Member #2
Old 02-12-2004, 10:46 PM
Stephen B Stephen B is offline
Re: Re: squeaking brakes after driving hard.....
Squeeking can be caused by a brake pad not properly fastened in the caliper assembly. The pad will move in the direction of the rotor untill it can no longer move then in a word, snap, back then follow the rotor again. This occurs several times over a milli second and sets up a frequency as it moves across the mating surface of the caliper or anchor contact points. The frequency becomes audible as a squeek.
Check to ensure the pads are as free of play as possible without them being bound tight. Then use specially designed brake silicone grease and lubricate the contact points and the contact points the pad resting on the piston will move into as it wears. Also be sure the pad that is seated on the piston has it's material surface cover between it and the piston face. The pad is usually a specially engineered thermal plastic that helps eliminate metal to metal contact and the noises that results.
Rear brakes are driving me insane! carlos crayon Colorado 11 01-21-2010 02:06 PM
Squeaking brakes after new tires put on?! stickxxxi Yukon 3 06-05-2004 12:31 PM
