Go Back   Automotive Forums Car Chat > GMC > Yukon
Old 05-23-2004, 03:34 PM
stickxxxi stickxxxi is offline
Question Squeaking brakes after new tires put on?!
99 Yukon, 4X4, 4-Door
I just switched out my 245/75/16 tires on stock rims for new 285/75/16 tires on after market rims. My brakes are squeaking quite a bit. Is this common w/ new rubber?
I bought the Tires and rims at Big O Tires.
Thanks.
Old 05-28-2004, 12:44 AM
Vroom2's Avatar
Vroom2 Vroom2 is offline
Re: Squeaking brakes after new tires put on?!
If this is a new problem, I'd definitely recommend having it checked. How many miles have you driven on the new wheels & tires? I assume you re-torqued the lug nuts after ~25-30 miles? Are the new wheels significantly heavier than stock? Obviously the tires weigh a bit more, and the combination may be putting an additional burden on your brakes?
Speaking of the brakes - how many miles since the last pad/shoe replacement?
Take care,
Jerry
Take care,
Jerry
'03 GMC Yukon Denali; www.suvworld.com/vroomvroom
'04 GMC Yukon Denali XL; www.suvworld.com/mrsvroom
'04 Toyota Tacoma XtraCab V6 4x4; www.toyotatruckworld.com/vroomvroom
Old 06-05-2004, 12:28 PM
cvoss2000 cvoss2000 is offline
Squeaking brakes normally aren't caused by the friction between the pad and the rotor, its caused by vibrations in metal parts like the caliper pressing against the back of the pad, the caliper pins, etc. Lubricate all the back of the pads, the pins calipers, etc, with brake parts lube from autozone. I did this on my explorer and it hasn't squeaked for 2 years.
-Cory
Old 06-05-2004, 12:31 PM
alphalanos alphalanos is offline
yeah my brakes started to squeak and i sprayed them down with a product called Brakleen. completely silent.
96 EJ6. Future home of boosted B18C1.
