Go Back   Automotive Forums Car Chat > Ford > Bronco
Old 02-12-2004, 07:43 PM
Bronco2 Bronco2 is offline
Axle seal
1988 Bronco 2,2.9 engine,4WD. Does anybody else have a problem with the left rear axle seal? Axle is good,no wear marks,replaced wheel bearing,tried a repair bearing(offset seal),leaked after a week,replaced axle with salvage yard axle,have used 3 name brand seals,no obvious cracks in housing,diff. vent is clean. Any ideas?
Old 03-09-2004, 08:47 PM
97chevyman's Avatar
97chevyman 97chevyman is offline
Re: Axle seal
axle worn outside spec, and wearing the seals too much.
Old 04-09-2004, 02:35 AM
kingmt kingmt is offline
Re: Axle seal
Replace the wheel bearning if it is still a problem you may have a bad diff. Is it making a loud noise when you put it in reverse?
Leaking front axle seals GeoPete Metro 2 12-16-2010 12:02 AM
Leaking Front Axle Seal (With Pictures) wagslick Silverado 10 11-27-2010 08:14 AM
"Economy" Axle seals from seals-it gosborne GTRA / GTWS / GTS 1 11-05-2009 07:55 AM
right axle seal leak Darkwing '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 7 04-03-2002 02:04 AM
trans-to-axle seal installation dmh Maintenance 0 02-15-2002 05:58 PM
