Old 02-11-2004, 09:52 PM
bajones33 bajones33 is offline
T5 tranny - Slight pause when shifting
I just rebuilt a T-5 tranny. I bought it used and had to replace the cluster gear in it which means a total disassembly of the tranny. This is the first time I cracked one open so I followed the T-5 manual closely. Now that I have the tranny into the car and there is a slight pause when shifting from gear to gear. Even though it's a short pause (1 second) this slows down my shifting bigtime when I'm shifting from 1st - 3rd because I have to wait before it slips into the next gear. I sometimes also have to play with it a little bit to get it to slide into reverse. Is this a synch problem? I made sure when I took the synchs out and put them back in that they stayed matched up. If it is a synch problem do they need completely replaced? Any help would be greatly appreciated.
Old 02-11-2004, 10:39 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
It most definetly is a synchro poroblem. Sadly your gonna have to pull it out and crack it open agian.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 02-12-2004, 01:20 AM
StangNut86 StangNut86 is offline
Send a message via AIM to StangNut86 Send a message via Yahoo to StangNut86
did you reuse your old blocking rings? those are the bronze rings between the shifter sleeves and speed gears. if you did, shame on you. they're relatively cheap and should always be replaced whenever you rebuild a tranny. also, check the inside of the shifter sleeves and make sure the points on the synchro teeth are still good. check the dog teeth on the speed gears... i could go on and on. knowlege is 90% of the battle here, make sure you do some homework and get to know as much as you can about tranny operation before the next time you tear into one =)
-Andy
'89 Mustang 5.0 - How fast? i'll know this weekend.
'86 Mustang LX - Shortblock is built, now for the rest of it.
"Put the subject before the verb, hmm? Fail this class, you will."
-Yoda teaches english class.
