Go Back   Automotive Forums Car Chat > Games > Gran Turismo Series
Old 12-31-2001, 02:08 PM
cracker196's Avatar
cracker196 cracker196 is offline
1000 mph?
Is it possible to make the Escudo go 1000 mph. I have heard this from friends and on an internet site. I am guessing this is a load of crap because I have only got it up to 315 mph or so. How can you make it go 1000? I have set the gearing correctly and everything, but it still only goes to about 315. What about popping a wheelie as well. I havn't been able to do that either, even though I have heard of people that did it. I set the downforce at maximum out back and at minimum in front. What do I do or is this even possible?
Old 01-04-2002, 06:23 AM
SkyNex721's Avatar
SkyNex721 SkyNex721 is offline
Send a message via AIM to SkyNex721
I have popped a wheelie with the Escudo. I haven't gotten it up to 1000mph though. I probably could have if there were longer straight a ways on the test track.
Old 01-04-2002, 06:53 AM
SkyNex721's Avatar
Ok I found the settings you need. You may want to save your original settings beforehand.
Tires: Super Soft front and rear
Suspension:
Spring rate:4.0 front/4.0 rear
Ride Height: 75 front/ 75 rear
Sohck Bound/Rebound: Level 7 All around
Camber/Toe Angles: All @ 0
Stablizers: Both @ Level 4
Brakes:
Brake BalanceL9 front/L9rear
Drivetrain:
Limited-Slip:Bring all LSD's down to 5
Gear Ratio: Bring the auto settings to level 48; then bring the final gear to 3.012; finally, set the individual gears as low {i.e., as far to the left} as possible. You should be left with:
1st 4.604
2nd 2.888
3rd 2.014
4th 1.485
5th 1.157
6th 0.875
7th ------
Others:
Downforce: 0.38 front/1.08 rear
ASM: 0
TCS: 0
VCD: 10%
All above information provided by John Damiani
Now that you set all that crap, just go to the Max speed race and start it. Then turn your self around in the opposite direction, that way you are going the wrong way. This way the race wont end.
Now the guy that wrote the article said that his top speed was like 891.3mph. I never got that high I only got into the high 600's. Anyways good luck and let us know how it turned out.
Old 01-20-2002, 03:09 PM
Jimmy2times Jimmy2times is offline
Send a message via ICQ to Jimmy2times Send a message via AIM to Jimmy2times
oh sheet, i need to borrow my mates ps2 again! i was gonna do the race to get that car but i couldnt be arsed but i think i will do it now!!
"You stick to building tractors and i will stick to building sports cars" -Enzo Ferrari, in a letter of reply to a man who complained that his gearboxes were not "all that". That man owned a company called "lamborghini"
Old 02-04-2002, 08:37 AM
Morpheus XIII Morpheus XIII is offline
I got the Escudo to 1137.5 mph with the trick.
Old 02-06-2002, 01:27 AM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
can you remember the settings you used? I can just top 1,000km/h but thats pretty far off 1,000mph.
Old 02-12-2002, 05:55 PM
As far as parts go, obviously max out everything, except for tires, in which I found Super-Slicks all around to work the best for me (I'll get more into why later on). Oh yeah, don't forget to keep your oil new; after a few runs doing the test track, you'll need to change the oil to keep power at tops.
And for the settings--
Suspension...
Spring Rate: minimized (far left)
Ride Height: minimized (far left)
Shock Bound: maximized (far right)
Shock Rebound: maximized (far right)
Camber: original settings (doesn't seem to make a difference)
Toe Angle: zero (haven't touched this yet; maybe some negative toe will help you leave the curve better before the straightaway)
Stabilizers: minimized (far left)
Gear Ratios...
1st: 5.295
2nd: 3.224
3rd: 2.216
4th: 1.610
5th: 1.235
6th: 1.000
Final: 2.000 (far left)
Auto Setting: 48 wide (far right)
Spoilers...
Front: minimized (far left)
Rear: maximized (far right)
Others...
TCS: off
ASM: off
VCD: 50%
Most of these settings are probably the same as what most of you already have, but it just doesn't happen every time. On average, I will hit ~700-800 mph the first straight, then use that speed to ride the wall through the turn after that. The real trick is, upon getting near the exit of this turn, you MUST stay off the outer wall, but start close to it, turn as hard as you can aiming for the inner wall and hopefully you will hit at least 230 mph right when the straightaway begins. In order to stay at a high speed through the turn, without understeering into to the outer wall, keep the speedometer at about a hair less than 230 by tapping the side brake to maintain traction and speed. The super-slick tires help you by allowing the Escudo to move more freely, which is important when leaving the turn; where you aim the car determines how much road you will get before the straight ends, and it's easier to aim the car when you have less traction by inducing mild oversteer. Near the end of the straight, the speed moves up exponentially, so lifting the Escudo even a second or two earlier is rewarded in the end of the straight by a few hundred miles per hour. Also, it pays to end the lift by crashing into the wall later in the approaching turn, not but rubbing the outer wall as the turn just starts (meaning, try to start on the outer side of the straight, but end on the inner side of the straight).
I haven't tinkered with the settings in a while, and it's highly likely there are better settings to make it easier, but it gets too tedious. Try different things and have fun. This is really only for the truly bored! It took me about 30 attempts before I finally broke 1000 mph.
Old 03-15-2002, 05:23 PM
Pikachoo's Avatar
Pikachoo Pikachoo is offline
Send a message via AIM to Pikachoo
I've had my escudo up past a billion mph using the glitch in the game on the Seattle Circuit II. Then the game freezes.
Cruising a Z24 right now, But I've got plans....
http://www.lingenfelter.com/lpe%20-%208%20sec%20Vette.mov
Old 03-15-2002, 08:32 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
yeah top speed was like2.3billion mph, may erase all saved info if you let it crash, so be careful.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 03-16-2002, 04:03 AM
Yeah, I read about that in some other thread, but there's no way I'm doing that. GT2 was known to have its small share of memory threatening bugs, and I don't intend to do instigate an already overly complex program.
Old 03-17-2002, 01:52 PM
crxlvr's Avatar
you can do the top speed thing safely until the car starts spiining on its rear wheels in circles, once that happens, quit race, but anytime before that is fine.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 03-22-2002, 10:19 PM
cracker196's Avatar
Got up to 419.2mph in the Escudo, but couldn't go above that before I got bored. It didn't seem like there was any speed left. It was doing the wheelie thing, but I still don't know about 1000mph. I used SkyNex721's setting which worked real well. There isn't enough straight on the Max speed test even when going backwards.
Old 04-05-2002, 01:27 PM
Chris's Avatar
Chris Chris is offline
Oldie
Send a message via AIM to Chris Send a message via MSN to Chris
Just pull out the memory card before racing
You can live in a car, but you can't drive a house!!
MSN: [email protected]
Old 04-07-2002, 05:45 AM
Thought of that, but still, the sound of my PS2 crashing doesn't seem all that appealing. I'll pass.
Old 05-08-2002, 10:09 PM
livindahighlife livindahighlife is offline
Send a message via AIM to livindahighlife
yea, i got mine up to 868.1, it was tuff, because it desnt give you much time, especially since the fron tend doesnt come off the ground until 230 mph.!
Caught doing 70 mph in 45 mph zone, but not true. Cop got it wrong? Shpyder Off-Topic 34 08-31-2004 08:59 AM
BMW E30 325i turbo. 9 seconds from 62 mph to 155 mph (100-250 km/h) BTT Car Videos 0 06-06-2004 08:17 AM
jerking at 20 mph & 35 mph (intermittent) gubbymj Montana/Montana SV6 9 01-26-2004 03:20 PM
Ticketed at 182 mph....and 205 mph JekylandHyde Street Racing 16 09-13-2003 12:41 AM
