Old 02-10-2004, 06:34 PM
turfup turfup is offline
Unhappy b16a problems
I put a b16a in my 91 civic DX and I am having tons of problems, any one who can help me out I would be really thankful. First of all my check engine light has been coming on from the start. I am not sure of the code though, it blinks twice. maybe 2-2-2. there are all kinds of wires not connected to the cpu. Secondly it idols up and down when I come to a stop sometimes. Also, it seems to have lost alot of power and does not redline the same as when I first got it. Since I have had it I have had to put in a new clutch which was new at install and and it seems to grind into gears frequently. I could probably list many more things wrong, but will start with this. I paid an arm and a leg to have it installed and just want it back to normal. Hopefully, this will be something that I can fix without spending much more money.
Thanks
Old 02-10-2004, 10:53 PM
Hybrid1990crx's Avatar
Re: b16a problems
how recently did you get that clutch? You know clutches have a break in period, right?
Old 02-10-2004, 11:31 PM
crx hf crx hf is offline
The idling up and down can be simply fixed by adjusting your idle it sounds like its to high.All you do is adjust the screw by the trottle body with a flat head screwdriver.As for checking the ecu make sure you dont count the first blink.Count the number of blinks and post back.
Old 02-11-2004, 12:43 AM
kapt kapt is offline
Send a message via AIM to kapt
Re: b16a problems
who installed it that ur havin all these problems?
Buildin up the b16 before i drop it in the CRX!!!
New 1989 CRX - i/h/e ;o
(retired)1990 Honda Civic DX HB - JDM b16a w/ hasport motor mounts, DC Sports Intake, APC short throw shifter, banzai motorsports muffler, neuspeed 2.5 inch drop pro springs, tokico blue shock/ struts, polyurethane energy suspension, dc sports rear strut tower brace, toucan front strut tower brace, JDM CRX rotors/calipers, Venom high-flow fuel pump, AEM fuel pressure regulator.
http://www.geocities.com/kaptr1d
Old 02-11-2004, 06:31 AM
jNYCe5 jNYCe5 is offline
Send a message via AIM to jNYCe5
Re: b16a problems
thats your first problem right there. take it back to the place who did the install and ask/tell them what you are experiencing. They should be able to tell you, better than any of us who cannot even see/hear the car, what is wrong.
Julian
Old 02-11-2004, 02:55 PM
Marc-OS's Avatar
Marc-OS Marc-OS is offline
Send a message via ICQ to Marc-OS Send a message via AIM to Marc-OS
If you paid a shop to do it, they better be fixing what they screwed up, and fixing it free of charge.
10 PRINT "MARC-OS 0WNZ J00!!!"
20 GOTO 10
RUN
4/8/04 - My CRX is officially dead, RIP Lucy
Old 02-11-2004, 04:45 PM
Re: b16a problems
It blinks 2 times consecuitively. I am clueless is that 2-22 or do I skip the first blink and say its 1-22
89Crx B16a problems CivicCRX89 JDM Motor & Parts info/chat 5 08-27-2007 03:53 AM
Help Please B16a Problem With Firing PhReAzE '88 - '91 Civic | CRX | Wagon | Shuttlee 6 04-15-2004 03:52 PM
b16a problem on crx, engine problem crxsirpr Let's get Technical! 0 03-02-2004 02:25 PM
A 1st gen b16a problem that will make you go nuts!! b16a91civicluvr Engineering/ Technical 6 12-23-2003 03:05 PM
b16a PROBLEMS!!!! HELP ASAP crabby760 Engineering/ Technical 19 10-20-2003 09:42 PM
