1.6 Dizzy On a 1.5 Motor? Cause Problems?
I have a D15B2 and I'm looking for a distributor for it.
The one I have now is a 2pin - 7pin Distributor, like this: But they say that one is for a 1.6L The one for a 1.5L is 2pin - 5pin Like this: I have no idea why I have that harness, but I don't want to go riggin a 5pin when I have 7wires that need to be connected...so do you think that if I just go ahead and buy the 2pin - 7pin for a 1.6 that it would be ok on my 1.5L? THANKS!!! |
i tried doing this too when my dizzy went, spliced all the wires together right, but the extra two are for like a crank angle sensor, and something else that the 1.5l motors dont have, the ecu keeps throwing codes and runs in safe mode. so best bet is to find a real dizzy for your car.
Name: Scott Stable Of Cars I have Owned: 1991 Honda CRX 1990 Oldsmobile Cutlass Supreme 2003 Honda Accord 1998 Chrysler Concorde 2007 Honda Civic 1997 Toyota Camry 1995 Saturn SC2 1996 Ford Taurus 1991 GMC Sierra 2002 Daewoo Leganza 1999 Dodge Ram 2007 Honda CR-V 2003 BMW 325i |
ya, you can use the 1.6 dizzy, but it looks for the mpfi and looks for sensors that you dont have so it wont run near as good as it should
Re: 1.6 Dizzy On a 1.5 Motor? Cause Problems?
it would be nice if they were the same...would make the MPFI conversion easier
"hi! my name is Lady, and i'm a HONDA-holic" ..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose! ![]() *~ I <3 the G Ride ~*~ I <3 OLD SKooL |
I have the dizzy off my DX motor just sitting around in the shop now waiting to be unbolted.
Honda Enthusiast
So lets say you have a JDM D15B VTEC. Would you use the dizzy from the D16A6 or use the JDM D15B dizzy?
- joe |
But that's just what I did...
Honda Enthusiast
the funny thing is, this is an HF model, it shouldn't even have that harness in there. I've been having hesitation problems, sputtering, and ocasional slight backfire in full throttle. Also whenever it happends, the tach wigs out and starts "floating and jumping" around... I've done just about everything except replace my dizzy and computer. tps, map, o2 sensors all replaced, wires, cap, rotor, plugs, and my forehead from banging it against the wall so many times. I've been trying to find out what the hell is making my car do this for the last 6 months it seems! I will KILL to make my car run right for once. |
HFs have multipoint so they need the extra 2 wires!!!
The problem is your ignitor, get a replacement distributor (ignitor is like $180, rebuilt dizzy w/ lifetime warentee is $200) I think I have a spare MPFI dizzy lying around if you want a cheaper alternative. ($50 + shipping, [email protected]) -Dustin
i have a 91 Civic DX with 3x as much money in it as what i paid for it i wish it was fast here is my website http://www.geocities.com/krustindumm/index.htm |
nah i took my friends 91 si dizzy and tried putting it on my 91 dx, i had to cut the connectors off and splice the wires so i can use the dx connector. it started sputtering and misfiring like crazy.
I bet you got the wires wrong because the DX (5-pin) and SI(7-pin) distributors are identicale EXCEPT for the extra sensor (crank angle) in the Si (7-pin) distributors.
-Dustin
Re: Re: 1.6 Dizzy On a 1.5 Motor? Cause Problems?
Too much of a hassle in my opinion.
Honda Enthusiast
Actually, I didn't put the dizzy on there in the first place, I had someone else do my swap for me, I was in the process of just changing my distributor due to sputtering and hesitation lately, and was going about it the way I thought to do it (get a dizzy to match the motor) (dx) well I got the thing in the mail and the damn connectors don't match. That was my problem and thx to Dustin
I think he might've solved it. Thx for all ur help guys.
i spliced em together using the electrical diagrams from the back of the helms, and had another person double check it to make sure, so i know i wired it correctly, but my ecu kept throwing the codes for the missing sensor.
I didn't have a problem doing it. I have an electricle diagram of the dizzy I'll try to find. The reason I suspect messed up wiring, there are 2 white wires.
-Dustin
