Old 02-09-2004, 09:45 PM
hfx_guy hfx_guy is offline
94 gmc 5.7 stalling
hi my 94 gmc 1500 4x4 5.7 is still stalling i am at wits end i have replaced the tps iac map coolant sensors(both cold start and guage) dist cap and rotor, excitor coil in the distributor the module in same plugs wires cleaned the tpi and changed the exhaust flange gaskets the truck will run for 5 to8 minutes then it hunts for an idle then quits and will fire back up right away and works well at over 80 km/h any ideas??????????????
Old 02-09-2004, 10:30 PM
rpage's Avatar
rpage rpage is offline
Send a message via Yahoo to rpage
Re: 94 gmc 5.7 stalling
I just had a similar problem with my 88 chevy. I disconected the timing advance wire,(Brown with black stripe), and adjusted the timing and it fixed the whole problem. The Check Engine Soon light came on though but my truck runs a lot better. I adjusted the timing by hear and not to spec also. Good luck
-Page
[email protected]
1998 Chevy C1500
1998 Volkswagen Beetle
1993 Jeep Wrangler
Old 02-10-2004, 11:20 AM
mr_anderson mr_anderson is offline
My 94 4.3 was doing the same thing here monday. The humidity was high. Today it ran perfectly with low humidity.
I'm going to check the base gasket for the tbi next.
Neo
Old 02-10-2004, 08:38 PM
thanx mr anderson mine does it in any temp from-28 to +32 degrees c its worse in the winter i've tried the iac turn on the key for 30 secs then with the key on unplug the iac then start it it should run ok at 2g plug it in and it stumbles again tomorrow i will clean the iac port and go from there.later jj.
Old 02-11-2004, 07:37 AM
EGR Valve
My EGR valve is completely stuck. I tried it and it won't move at all. I am also going to clean the iac port. I am hoping to get some bad weather down here so I can test it. Wally
Old 08-02-2007, 11:50 AM
briang0 briang0 is offline
I'm wonder if this problem was ever solved I have the same problem and the dealer said they don't know whats wrong with it. HELP
Old 08-02-2007, 12:48 PM
2000CAYukon 2000CAYukon is offline
This thread is 3 1/2 years old. You should really start a new thread.
//2000CAYukon
please help 5.7 liter hawk713 Caprice 1 04-22-2010 08:05 PM
1996 gmc 5.7 won't start-no spark 600cuin Sierra 5 11-13-2009 12:03 PM
a CHALLENGE!! ('93 5.7 Intermittent no-spark) cmjj42 Roadmaster 3 05-06-2009 11:55 AM
1990 gmc 5.7 to 5.0 engine swap? 1979Lee Sierra 5 07-14-2005 04:03 PM
93 gmc 5.7 idles poorly and stalls under load jorgeq2 Sierra 0 12-07-2003 11:01 AM
