Old 02-09-2004, 01:13 PM
Blown R1's Avatar
Blown R1 Blown R1 is offline
Ball joint question......
just out of curiosity what are you best methods of ckecking for bad balljoints 2 or 4 wheel drive 1/2 to 1 ton , dont matter . dont have an alignment rack any info would be great...
"gone 240 in the 1/4 @ 6.23"
Old 02-19-2004, 11:33 PM
fordin K fordin K is offline
Re: Ball joint question......
well you can take a look at the Haynes manual or similar. If I recall correctly, jack up the front. grasp top and bottom of tire and check for play. if you grasp front and rear of tire and check for play that is for tie rod wear. you might check with the manuals.
Ball joint installlation for 2001 Taurus SEL Doug Tatham Taurus | Taurus Wagon 10 09-28-2020 07:37 AM
ball joint or tie-rod end? thinmint Dakota 1 03-07-2010 10:39 PM
Ball Joint question - confused... caffeineaholic Caprice 8 12-19-2009 06:17 PM
ball joint? tie rod? HELP! cjedstrom Cougar 2 11-26-2009 05:53 PM
ball joints question jjguitar Engineering/ Technical 3 08-12-2002 10:04 AM
