Old 08-11-2002, 05:12 PM
jjguitar jjguitar is offline
Send a message via AIM to jjguitar
ball joints question
Would anyone know about how much it would cost to get the ball joint replaced in one wheel?
Old 08-11-2002, 05:19 PM
Steel's Avatar
Steel Steel is offline
you mean like, the CV joint on the driveaxle? Um, well its not too terribly difficult to do it yourself, just pick up a haynes manual and the part, if its the same part im thinkin of.
Old 08-11-2002, 10:21 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Yeah, I had a CV joint in my Jeep go bad and I bought a new one for about $60 bucks and they gave me a $20 dollar core charge for the old part. It was quite easy to install, unless you have to take a strut out to get to it. In that case you will need a spring compressor.
Old 08-12-2002, 10:04 AM
enginerd's Avatar
enginerd enginerd is offline
not a cv joint, a ball joint. The ball joint is located on the top and bottom of the spindle between the spindle and the a-arms and allow the spindle to hinge. I can't give you a dollar amount because i've always replaced mine myself. Teh joints themselves are inexpensive, but most of the costs is labor since most of the times the coil springs/ torsion bars need to be removed or relaxed.
Kittyloaf™ spectrum analysis
