Go Back   Automotive Forums Car Chat > Porsche > 924/944/968
Old 02-09-2004, 12:14 AM
Tanreall Tanreall is offline
Web cam and lifters??
Ok so I recently installed a web cam to give my N/A a little extra go. I put so assembly gresse on the lifters to keep them in place while I put the cam housing on and it went on fine and everything seems in order but the darn thing won't start. The fuel is getting there and the spark is getting there too but the valves just aren't opening so my best guess is that the lifters aren't pumped up with oil. I just changed my oil and put in a lighter weight too 5 - 30W I tryed to start it 3 times and still no good. so if anyone thinks of a solution please help me out.
Thanks in advance
Old 02-12-2004, 02:29 PM
930guy 930guy is offline
Re: Web cam and lifters??
Even if the lifters are not pumped up the car should still run it will just be noisy. I would check the timing or dist. cap or rotor
anti freeze leak after getting cam and lifters done in my 3.4 2005chevimpala Impala | Impala SS 6 01-16-2009 11:05 AM
if i remove a cylinder head do i have to remove the cam and lifters ? jasonvg_2001 Tracker 0 12-02-2007 11:42 PM
1996 350 cam and lifter question Tim in AZ C/K 2 09-29-2004 12:41 AM
Dad Faces No Charges for Nude Pictures of Daughter Taken From Web Cam taranaki Politics, Investments & Current Affairs 15 08-29-2003 02:32 AM
Thinking of going with a web cam, which one? doug294 '88 - '91 Civic | CRX | Wagon | Shuttlee 0 08-18-2003 12:09 AM
