Brake Problem
My girl friend owns a 99 Cougar. About a year ago when ever you would step on the brakes it would start to shake the steering wheel a little. I thought it was the router wearing out. they did look really bad so I replaced them also put new pads. That seem to have stop it for about a day. Now when you press the brakes it makes the whole steering wheel and the dash to shake really bad. Can any one help?
your rotors are warped.
![]() "The CEG Nazi" www.contour.org 1996 Ford Contour SE - Sold 3.0L V6 and Arizona Dyno Chip Turbo Kit 364 whp, 410 wtq @ 16 psi and only 4,700 rpms. 1999 Tropic Green SVT Contour - Bone stock and MINT |
no I replaced both of them because I thought that was it too. That did not slove the problem. any know what it might be?
Re: Brake Problem
wheel bearing? alignment? bent hub?
Re: Brake Problem
If it stopped for a day you were on the right track.
Who put the new rotors and pads on? Did they tourque all the lugs with a tourque wrench? If not, you could have new warped rotors. The lugs all have to be tourqued to the same ft.lbs. |
Yo i think i might know what could be the problem i had the same thing with mine if you give me a call i can tell you maybe wat the problem is 2679686117 my cell Thanks
mark |
lower ball joint
i had the same systoms in my 90 and replaceing the lower ball joint fix it |
