Old 02-07-2004, 08:32 PM
jatos jatos is offline
Question Newbie needs help
Today on my way home from work my car (89 Sunbird) just croaked. I put it in gear at a stoplight and it would not accelerate and when it is in gear it makes this constant loud cranking sound like something in my steering or gears is just getting chewed up. It is not noisy in park, the noise is only when it is in Dr or rev. i have no drive. Any help would be appreciated.
Thanks
Old 02-08-2004, 10:13 AM
KC Ron Carter KC Ron Carter is offline
Hmm,
Transmission replacement MAY exceed the value of the car!
Unless there is something you really like on this car, I would be car shopping.
Later,
Old 02-08-2004, 07:37 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
It might just possibly be your torque converter has failed.
If you are lucky, you could pull the transmission, and just replace the converter.
It may be okay if the broken converter did not contaminate the fluid and the rest of the trans with metal shavings.
However, as pulling the trans is $300 on its own, you may as well rebuild the transmission too, to be sure.
And as KC says, it might be more than the car is worth.
newbie need help onastick '88 - '91 Civic | CRX | Wagon | Shuttlee 3 09-07-2002 01:35 PM
newbie needs help cue-2-8 Sentra | 200SX (USDM FWD) 1 08-19-2002 11:49 AM
honda newbie needs help sinfestboy Integra 3 07-16-2002 06:14 PM
Newbie needs help..... dan_nz_man Audio/Security 1 03-27-2002 04:17 AM
