Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 02-07-2004, 12:28 PM
Gchaviano Gchaviano is offline
No computer codes
I have a '93 Crown Victoria. The PCM is not giving out any computer codes.
Old 02-08-2004, 05:50 PM
ModMech's Avatar
ModMech ModMech is offline
Re: No computer codes
Unless the check eninge light is on, there may not be any codes to "give out".
Old 02-09-2004, 12:18 AM
amo4387622 amo4387622 is offline
the engine light does not have to be on to get computer codes. probly why u dont get any codes is because if u have a bad sensor and it is sending a high or low signal to the PCM that number might be in a certain range that the PCM is with at the factory and runs the car perfectly with, and if it does not go higher or lower than that range the PCM will not set a code.
p0420 computer code rwfrank Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 4 05-28-2004 12:18 PM
Motor pings, knock sensor computer code JWMAX Engineering/ Technical 4 03-12-2004 08:07 PM
89 Caravan - Does Not Start - Computer code 55 goldenmole Caravan | Voyager 4 02-26-2004 10:58 PM
1985 Edorado No Power To Computer Code matdaddyo Eldorado 2 10-31-2003 08:56 AM
read computer codes w/o device gls_axie Jetta/Vento/Bora 0 05-11-2003 11:17 PM
