Old 02-07-2004, 02:30 AM
six speed six speed is offline
Talking 3.1 Vs 3.3
Okay I don't want to start an argument but I was wandering wich was faster ,because a guy online told me the 3.1 was at 189hp while the 3.3 only made 160hp.I was wandering if anyone knew the truth, if so I would really like stats .stock vs stock ofcourse.
Thanx
Old 02-07-2004, 05:11 PM
mdb25 mdb25 is offline
No, that guy is wrong. The 3.1 makes 155hp, not 189. The 3.3 does make 160. It's a pretty close match, but I can't say for sure which is faster. My guess is that if you get the 3.3 with a 5 speed, then you are going to have a faster car because the 3.1 GA GT's only come with auto.
Old 02-10-2004, 10:44 AM
95_GrandAM_GT 95_GrandAM_GT is offline
Send a message via AIM to 95_GrandAM_GT
Re: 3.1 Vs 3.3
that is not true my 3.1 is putting out 210 and it doesnt really have much done to it. Just a chip and performance air filter but it is real quick and the 3.3 does have traction control, but it will be real close...good luck
Old 02-10-2004, 02:45 PM
YES IS IS TRUE. I have the numbers sitting right here in front of me.
STOCK 3.1 = 155hp
STOCK 3.3 = 160hp
Be sure to check your facts before making a reply.
Old 02-11-2004, 08:55 PM
The Right Formula's Avatar
The Right Formula The Right Formula is offline
Send a message via AIM to The Right Formula
Re: 3.1 Vs 3.3
mdb25 is correct with the numbers.
When I had my 1993 grand am, it was very sweet--seemed like a lot of power for 160 hp. I was rather disappointed with the engine performance of the 3.1, but oh well--nice car regardless.
You say 210? Flywheel or wheels?
--Jason
Old 02-23-2004, 10:02 AM
achievasc92 achievasc92 is offline
wow, I have the sudden urge to clear up a few things.
-the 3.1 MPFI engine only made around 135 hp.
-the 3100 SFI engine made 160 in 94-95 (before the MAF sensor was added) and then made 155 hp unitl it was upped to 175 after the heads and intake manifolds were revised to more closely resemble that of the 3400 V6
-The 3300 V6 made 160 hp but was only mated with a 3-speed automatic (th125, and th125-c, depending on the year) No 5-speed was ever offered on the 3300 or any GM FWD V6 since the 3.1 and 2.8 MPFI engines.
IN a race from a stop, the 3100 would most definately beat the 3300 because of its better transmission gear (the 3-speeds first gear is extremely tall for obvious reasons) But from highway speeds , a 3300 should be able to hang with a 3100 fairly well. I should know I own one of each
1991 Cutless supreme 3.1 stalling mandude Cutlass Series 9 02-06-2015 01:16 AM
knocking after oil change 3.1 moemo Cutlass Series 1 10-20-2010 07:37 PM
2002 3.1 thermostat removal DigduG1975 Grand Prix 1 05-29-2010 09:47 PM
1995 cutlass supreme water pump 3.1 moemo Cutlass Series 1 05-02-2010 09:55 AM
3.1 interchange info please. Ponyak Grand Prix 2 06-08-2009 11:58 AM
