Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon
Old 02-07-2004, 12:40 AM
NJH_Habitatpro NJH_Habitatpro is offline
Send a message via AIM to NJH_Habitatpro Send a message via Yahoo to NJH_Habitatpro
What would be some safe mods after this stuff?
I have a air intake, muffler, new coil, 60mm throttle body, headers. I was thinking about a high flow cat, pulleys, and cam gears. Is that a pretty good idea or should I do something else im trying to get power and not mess up my car. Thanks for the replys.
Old 02-07-2004, 07:25 AM
HotBoys09's Avatar
HotBoys09 HotBoys09 is offline
Send a message via AIM to HotBoys09
Re: What would be some safe mods after this stuff?
Well first off all, if you want good traction/power deliverance, tighten up your suspention. It deff. helps like motor mounts, lower, braces, and tires. All off those are 100% safe, CHEAP (except good tires and springs, but I don't think that those parts would be too much for a neon) and helps immensely...
Oh and you have CAI, Headers, muffler, and TB. It's doing NOTHING unless you free up all those pipes, that's the only way youll get the most of your mods already, and future ones. But every little bit helps. But sound like you have a good project going, good luck.
P.S. OH, try to shed some pounds, helps ALL around.
1999 Plymouth Breeze
1995 Ford Probe GT - R.I.P.
1987 Dodge Daytona Shelby Z
WTB 98+ Formula/TA or Z28
Old 04-14-2004, 04:36 PM
Fenixfire077 Fenixfire077 is offline
Send a message via AIM to Fenixfire077 Send a message via Yahoo to Fenixfire077
free 2hp boost! get this, there is a piece of weather stripping under the hood on the pre-2000 neons, it's right near the windshield, if you pull that off, it will actually give you a 2hp boost!
Old 04-14-2004, 10:46 PM
blachdohcneon blachdohcneon is offline
def get an UDP and mp pcm, that 2hp thing is a little of stretch, all it does is cool down the engine bay, not sure how thats measured in hp.
Old 04-14-2004, 11:09 PM
FuriousMachine95's Avatar
FuriousMachine95 FuriousMachine95 is offline
Send a message via AIM to FuriousMachine95
If you have the SOHC I would definatly think about getting the magnum camshsaft and valve springs put in. One of the many things I'm planning with mine. Takes you from stock 132 hp to 150. Nice. Very nice. You can get all the parts for around $250. Go to http://www.neons.org/forumdodge/ for more info on that. It's under Magnum SOCH Camshaft and Valve Spring Upgrade Info about 1/3rd the way down the page.
Old 04-15-2004, 09:15 AM
The magnum camshaft and valve springs WILL NOT get you to 150hp. you must have the higher flowing magnum head and intake manifold to see that kind of gain.
Old 04-15-2004, 06:13 PM
I thought they were the only difference between the to engines. What else is there?
Acting my age is no fun.....
Old 04-16-2004, 06:54 PM
well look at the differance in port sizes, http://www.neons.org/forums/viewtopic.php?t=66442
its much higher flowing, also the intake manifiold has two sets of runners, it uses the longer one's for low rpm then a solenoid flips a valve and the shorter runners are used for high rpm. also the stock exhaust manifold is much better then the other sohc's
Old 04-16-2004, 07:34 PM
Ok. Thanks for the lesson. I guess I have a little more research to do before I do a swap then.
Old 04-19-2004, 12:43 PM
drag1320neon's Avatar
drag1320neon drag1320neon is offline
Send a message via Yahoo to drag1320neon
it all depends on how much money you have and how much comfort youre willing to sacrifice. i mean hey, depending on where you live a/c,p/s, might not be needed. youll notice a slight difference there. but after you get the race pulley, and allum. flywheel, you drop you times like crazy. get a mopar ecu and a crane cam, you got one cool ass neon for the street
you aint gotta like me, you just mad cause i tell it how it is, and you tell it how it might be
CHECK OUT MY CARS HERE!
drag1320neon and 209neon's babys < 209 neon finished!>
What do you guys think about this stuff? tr10av Car Audio 1 04-23-2006 06:42 PM
What are some aftermarket mods for the Gallardo? advan24r Gallardo 28 05-26-2004 03:42 AM
I have a 1990, What are some cheap mods to increase hp? samieg MX-6 1 05-05-2004 11:22 AM
What would be the value of this Cavalier 03cavyTT Cavalier 7 03-22-2004 07:15 AM
What are some 996 mods? Chips? Exhaust? Sharp 911 0 12-18-2002 08:58 PM
