Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon
Old 02-06-2004, 09:55 PM
raiders73 raiders73 is offline
low voltage
how do I kick up the voltage to my tp sensor, it give the code of p0122 what would be the steps on fixing the problem, and were would I start first.
Pac_Man
Old 02-09-2004, 08:24 PM
pegasus757 pegasus757 is offline
Re: low voltage
You dont adjust the voltage to the throttle position sensor. the pcm puts 5 volts to the tps ..(the tps is a variable resistor) at idle output to pcm is low ,at wide open output is high. the tps is wearing out and needs replacing.
02 sensor low voltage problems wanda Venture 1 06-17-2004 01:16 AM
won't start / low voltage @ fuel pump room217 Off-Topic 4 07-10-2003 05:17 PM
E38750i1995 with low voltage faults ddennig 7 Series 1 12-02-2002 08:17 PM
OBD-II CODE P0102 MAF Circuit Low Voltage Input blazintex Blazer 2 11-22-2002 11:59 PM
